Like Tree4Likes
Tamiya TRF417
Old 11-07-2011, 05:42 PM
  #2206
TryHard's Avatar
Originally Posted by miguelfs14
Hi Guys!
I'm running in mod and tamiya drive shaft blades are really bad, because get fragile broken and the lost makes wear in diff cups. If you put a couple of new, the next new blades maybe broke in two mains because wear in diff cups. So you may change diff cups too.
I tryed spec-r and maybe works best, but not for a long time, maybe 4 mains.
I'll try to test 3.5mm spec-r for yokomo, making diff cups for this.
Anyone who solved wearing in drive shaft blades?
Thanks!!
Use the Tamiya diff...
Other than that, you answered your own question. If the diff cups are bad, then they will eat the blades, even if there is only a little bit of wear. This will happen regardless of the size of blades.
Changing worn out blades is the best thing to stay on top of. If they are looking thin, then change them regardless... they are there to protect the driveline, so consider them consumables!
Spec-R do have some newer outdrives out, and I've also tried the Spec-R blades as well (I now have a good stock of Tamiya and Spec-R blades, hehe), but the biggest thing is to make sure the outdrives are in a good condition. I'll generally get over 10 runs with a modified out of a set of blades.
HiH
Ed
TryHard is offline
Old 11-08-2011, 01:25 AM
  #2207
CraigM's Avatar
Trader Rating: 34 (100%+)
where's a good place to get the tammy diff? I decided to give my 416x a run today after a year on the shelf (on display, with it's trophies lol) and the spec r diff had dropped it's guts everywhere
CraigM is offline
Old 11-08-2011, 02:42 AM
  #2208
chrisk's Avatar
Trader Rating: 32 (100%+)
Craig, I have a new one if you want until you find one, just pm me when you want it.
It hasn't been opened yet
chrisk is offline
Old 11-08-2011, 02:43 AM
  #2209
chrisk's Avatar
Craig, better still take the whole car (417) and run that. Im running my 416
chrisk is offline
Old 11-08-2011, 11:19 AM
  #2210
GMartinez's Avatar
Trader Rating: 91 (100%+)
1 More left instock
http://www.superiorhobbies.com/istar...id=TAM42200!SH
also well stocked in basic parts
GMartinez is offline
Old 11-08-2011, 11:21 AM
  #2211
GMartinez's Avatar
Full stock of Spec R
http://www.superiorhobbies.com/istar...&numperpage=30
Old 11-08-2011, 06:32 PM
  #2212
Racing4Evo's Avatar
http://http://www.speedtechrc.com/st...d=964&id=11635
I think they ship internationally for a reasonable price.
Racing4Evo is offline
Old 11-09-2011, 04:04 PM
  #2213
Hi guys,
A little update on my (past) problem with the vibrations in the front. As mentioned previously, I removed the problem by using Litemodz CVS's in the front. Well, I am having trouble with the durability, so tonight I decided to give my previous stock Tamiya CVD's a go one more time.
My servosaver was getting tired, so I replaced that. And when that was replaced, I put it on the track, and the problem with vibrations was gone!
So I am back to using the stock CVD's until Tamiya launches their DCJ's!
Nilks is offline
Old 11-09-2011, 07:43 PM
  #2214
Trader Rating: 47 (100%+)
Anyone know who i can source out for ALUM steering blocks and caster blocks. Thanks for the help.
transplantlife is offline
Old 11-10-2011, 12:36 AM
  #2215
JoeyE's Avatar
Trader Rating: 45 (100%+)
JoeyE is offline
Old 11-10-2011, 02:35 AM
  #2216
Trader Rating: 22 (100%+)
Originally Posted by JoeyE
Are they 417X kits?
Where can I get one?
bjspinner is offline
Old 11-10-2011, 07:13 AM
  #2217
artwork's Avatar
Trader Rating: 88 (100%+)
OMG!!!!!!!!
artwork is offline
Old 11-10-2011, 10:47 AM
  #2218
Racing4Evo's Avatar
I count 96 kits. Is this in Thailand at the distributor???
Old 11-10-2011, 10:55 AM
  #2219
Trader Rating: 12 (100%+)
Just creamed myself.....
Turillo is offline
Old 11-10-2011, 11:23 AM
  #2220
ShaunMac's Avatar
SHOW US YOUR KITS!!!
ShaunMac is offline
