Like Tree86Likes
Hpi Pro 4
Old 04-09-2004, 10:04 AM
  #3271
TeamPRP's Avatar
Originally posted by RC Driver Gary
Yup, Memorial Day Weekend, but there aren't any one-ways allowed, only dual diffs or a front spool (hint, hint ) We should know tomorrow who's in and who isn't in for the RROC
A front spool would be cool, wouldn't it?
TeamPRP is offline
Old 04-09-2004, 10:05 AM
  #3272
rc-zombies's Avatar
put me down for 1..maybe 2..
rc-zombies is offline
Old 04-09-2004, 10:07 AM
  #3273
RCGaryK's Avatar
Especially if it were ready and could be tested before the reedy race.
RCGaryK is offline
Old 04-09-2004, 10:16 AM
  #3274
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Originally posted by Michal101
Has anybody tried their Pro 4's on asphalt yet this season and if so what changes did you make to your box setup?
Mike
The stock setup worked pretty well on a tight, indoor asphalt with Sorex 36R tires. Go back a few pages, there was a few setups posted....
Buddha
RCBuddha is offline
Old 04-09-2004, 10:36 AM
  #3275
RCBuddha's Avatar
Default Re: gear problems
Originally posted by coastaltony
My cars problem is the rear, left,
upper/inner ball-cup. Four times it
popped off (in action). Three
times lost the out-drive saver, four
times "dnf".
As a Team Losi -sponsered driver once told me: If you wanna stop breaking parts, stop hitting stuff....
j/k tony....
Try replacing your ball cups with either Dubro ends, or ends like the one that is on the bell cranks.
RCBuddha is offline
Old 04-09-2004, 10:37 AM
  #3276
cartmen34's Avatar
Originally posted by rayhuang
Dribble a little CA on the droop screw and wait for it to harden fully. Then screw it back into arm. SHould solve that problem fully.
Ray
Of course! I knew that....I really did! lol (darn I'm out of practice wrenching on these things) lol
I'll give that a try tonight. Thanks Ray!
cartmen34 is offline
Old 04-09-2004, 11:37 AM
  #3277
Super Steve's Avatar
http://www.rctech.net/forum/attachme...&postid=814503
hmmm...
what do you guys think?
too girly?
Super Steve is offline
Old 04-09-2004, 11:46 AM
  #3278
rayhuang's Avatar
Hey guys,
How true is the driveshaft on this car (center driveshaft)? MInes got quite a bit of runout in it. Enough that its easy to see.
If thats normal-cool deal.
Ray
rayhuang is offline
Old 04-09-2004, 01:54 PM
  #3279
this might be not be the right place for this, but since it's pro 4 related i figured it should go here..i've taken a pro 4 and converted it to off road...my question is i'm running a 13X2 with a 75 tooth 48 pitch spur...what would be a good starting point pinion wise?
SCHMACHER is offline
Old 04-09-2004, 02:12 PM
  #3280
RCBuddha's Avatar
Hey guys,
Ray
Mine wobbles, not terribly, but enough for me to notice when I spin the car on the bench. I've noticed NO ill effects when running the car.
RCBuddha is offline
Old 04-09-2004, 03:27 PM
  #3281
Kevin K's Avatar
Trader Rating: 32 (100%+)
Hey guys,
Ray
Ray....To me it does not look any worse then what the average TC3 has. I dont think you need to worry about it much.
Kevin K is offline
Old 04-09-2004, 06:20 PM
  #3282
rayhuang's Avatar
Thanks all. I built the new diff (yup-this is what i do on Friday nights!!) already and am contemplating tearing into the shocks next..... I built it with a TC3 spring so hopefully I wont expereince the loosening diff problem.
Okay-build up motivation to do shocks.....ughhhh...
rayhuang is offline
Old 04-09-2004, 07:11 PM
  #3283
popsracer's Avatar
Pops....is the chassis sitting on a flat surface with out any shocks or tires on? If the chassis is not sitting flat on the ground then it might bow and that would lead to the holes not matching up. Just a thought.....
Yes the Chassis sits nice and flat without the Upper Deck. I am building step by step per the Kit manual, so I haven't made it to the Shocks yet.
Everything that mounts to the Chassis was tightened in a cross pattern. I even tried leaving the Camber link mounts loose on the Gear Boxes (thinking warping was here) but to no avail.
Going to contact HPI and see if they will warranty the Deck. I hate to pay for another one and have the same problem occur.
Thanks,
popsracer is offline
Old 04-09-2004, 08:12 PM
  #3284
Brian McGreevy's Avatar
Hey Ray, here's some motivation...they're BUTTERY smooth when you're done. Like WOW
Brian McGreevy is offline
Old 04-09-2004, 08:39 PM
  #3285
coastaltony's Avatar
Trader Rating: 13 (100%+)
Ray, the shocks are a
quicky. Remember this, once you get
the shaft 1/2 in, it's all
over!
coastaltony is offline
