Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 02-14-2012, 06:17 AM
  #7711
Originally Posted by theatriks
Well im gonna check ...good idea.....are the f104w steering links that bad to race with?
Nothing wrong with them to get you running, years ago it was all we used and surprisingly enough the steering never fell apart all the time. Tamiya still supplies it in many of their kits so there's more running those thin links than using turnbuckles.
The Z bends do wear the holes bigger in the servo saver over time and the small plastic ball joints will pop off more often than bigger ones, but for a few weeks you aren't going to notice much difference.
The only downside is that you can't adjust the length as fine as using turnbuckles.
terry.sc is offline
Old 02-14-2012, 07:05 AM
  #7712
Originally Posted by dfx
Don't know Your local track rules, but in some other championchips is this illegal. The rules are usualy like only F1 tires allowed and max. width 45mm (F103 size)...
Not in our track rules...
I used normal tires and car's width, but when someone on your track takes advantage of that... I have to do the same :-)
SquirrelCZE is offline
Old 02-14-2012, 07:06 AM
  #7713
NiMo's Avatar
If you are racing outdoors on a slightly bumpy track then the wires may be better.
I remember a guy (Terry should know him ? - Graham Hill) who raced at the (no longer) Basildon circuit which was very bumpy, set FTD in round 1 and found his servo loose, tightened it for round to and found the track difficult like the rest of us, in round 3 he loosened the servo again and went fastest of the day.
From that point on many of us ran wires outdoors as the car felt less twitchy and sensitive on the steering.
NiMo is offline
Old 02-14-2012, 08:15 AM
  #7714
theatriks's Avatar
Thanks guys I love coming to this thread ....the answers come quick and the advice is usually rite.
theatriks is offline
Old 02-14-2012, 08:48 AM
  #7715
wwddww34's Avatar
Trader Rating: 9 (91%+)
Hey all you Formula One racers, have you signed up to race your F1 car at the 2012 ROAR Carpet Nationals coming on March 16? Hurry up and register before time runs out! Click here to get signed up.
Click
HERE to see a countdown to the 2012 ROAR Carpet Nationals
wwddww34 is offline
Old 02-14-2012, 08:56 AM
  #7716
lightfoot's Avatar
Originally Posted by rays_tt
Hi guys, in terms of rubber tyres would you recommend getting Ride or Shimizu's?
I'm after the best gripping rubber tyres.
Shimizu 0571 and 0572, stock inserts...
Check out: http://uf1series.com/_sub_pages/2012/uf1_101.html
You can get these tires at TQ:
http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
http://www.tqrcracing.com/shop/produ...yword=&pg_no=2
lightfoot is offline
Old 02-14-2012, 02:21 PM
  #7717
Trader Rating: 13 (100%+)
F104 suspension arms and foam wheels are finally back in stock!
stitchy is offline
Old 02-15-2012, 06:21 PM
  #7718
theatriks's Avatar
Hey guys just wanting to know what springs and shock oil everyone is running for carpet ...medium bite.....pit rubbers.
Old 02-16-2012, 02:07 PM
  #7719
mattwoodcraft's Avatar
Ride soft front springs I have been coating the shaft with 1000wt oil, red rear tamiya spring with 25 at oil in the shock
mattwoodcraft is offline
Old 02-16-2012, 03:14 PM
  #7720
lightfoot's Avatar
Default UF1 Series
The final race of the 2012 UF1 Winter series this Saturday at TQ in Chino California...
Doors open at 10AM
Qualifying starts at noon...
Free UF1 Shirt when you register, quantity and sizes are limited, first come first serve... two styles available....
Old 02-16-2012, 03:30 PM
  #7721
theatriks's Avatar
Ok thanks will try it .....i have heard a lot of guys coating the king pin i will try it too....does it make that much of a difference?
Old 02-17-2012, 12:02 AM
  #7722
It can I race on a large asphalt track which was in the day for 1/8 gas what I have noticed is that it can smooth out the steering and takes away the binding which can happen when left dry. The other oil I also use is the oil that is used to oil the bushes in the motor it's a tuning option you would really need to try a few different ones to feel the results
Old 02-18-2012, 09:23 PM
  #7723
spring71's Avatar
Smile
2012 Ultimate F1 Winter Series Final Race at TQ RC RACING.
We had strong turnouts from the beginning to the end.
We had full A,B,C,D and E Main today. F1 class is strong and growing fast at Socal.
Click Here for more pictures., Click here for the results, UF1 Series Homepage
spring71 is offline
Old 02-19-2012, 08:10 AM
  #7724
RonF's Avatar
Default I need some mirrors..
I need 2 sets of mirrors from the McClaren or F60 or F104 body if anyone has any for sale. Or can point me to a parts tree somewhere? BPshadow? I need the mirrors, the oring and if you can the small body clip.
RonF is offline
Old 02-21-2012, 07:49 PM
  #7725
Talking Noobie here
Hey guys! My names Brandon and I'm new to this forum and F1 style racing.
I've been running my f1pro on carpet for a few weeks now and its slowly getting dialed in, but i still cant seem to keep it from traction rolling without being to tail happy in the corners, so I have a few questions for people running on carpet.
1. What diameter foam tire seems to work best for short carpet tracks?
2. What is the weight that seems to work best for you?
3. Is there any things that are super important when setting this up for carpet?(sound like a stupid question)<<<noob
Any help is greatly appreciated!
Brandon C
BrandonC is offline
