Tamiya F104 Pro!
#6961
when it comes to it, this cars handling is perfect!
it can handle throttle everywhere (which is privilege of 4WD) but i have problems with "flip over" at low speed .... today i figured out that front spring suspension wasn't good.... and i have new tires, so i think about "round off the edge of the wheel" (i used translate.google to write this, so maybe i wrote it wrong).
P.S: Rear suspension is really hard I didn't notice that undertray touches the ground....
and this undertray is perfect because it defends the rear shaft (guys with Xray 2WD cars broke at least one per race... i do not O:-) )
#6962
Still having no joy finding a Brawn body for my F104. Any 1 got any ideas? dont think it will look right on a F60 body
#6964
The exotek 104 doesn't fit with the one piece yeah racing motor mount.
Not with out sanding down the left rear link arm so it doesn't bind.
Thanks for advice, but it's not best option for me... because i use Yeah Racing Aluminum Motor Mount Single Piece and i would have to change complete motormount... that's the reason why i asked about the TRG :-)
another thing: I have Tamyia F104GT in development and we have made (me and my father) our own dumper solution, but our solution is still too big to be used in F1 car :-)
P.S: i have pics of that, but i can't post link ...
#6966
#6968
Hey guys,
This Saturday we asked Kyosho to open the Mini Z F1 Class for their fall classic race to be held this coming Saturday 3rd and they have agreed. We have four cars confirm, but still need at least two to make the minimum six required.
If you have not experience running your Mini Z F1 at Kyosho this is a great chance to do so, plus you will be supporting the F1/ Mini Z scale efforts to be alive and racing again in southern California.
I support anything F1,we hope to meet you Saturday at Kyosho.
Cheers, Marcos
PS I been part of Mr. Lightfoot’s UF1 gang since the beginning (2009), for reasons outside our control Kyosho had previously schedule this race the same day as November’s 2nd round of the UF1 winter series. I will always promote staying away from the UF1 schedule or any other F1 race so we get more (including and not excluding) options for all F1 enthusiasts.
Sorry in advance for this unwanted situation.
Click for race info.
http://www.kyoshoamerica.com/R-241-Raceway-_c_15.html
Cheers, Marcos
#6969
If you have a low-pro servo then this is the best way;
http://www.exotekracing.com/f104-bolt-in-servo-mounts/
What are the blue 6mm spacers? Exotek part? Tamiya part?
Thanks!
#6972
Thanks. Ill give those a try. What is the pound weight of the CRC side springs and the Tamiya blue center spring,I'm using AE side springs and center shocks setup the same as my other AE pan cars. Also, what about ride heights, front and rear. I heard that running the front high and the rear low helps a whole lot. Any ideas?
Use any old spacers- 6mm worth of hinge pins spacers will work.
#6973
#6974
I used this threaded spacer: http://www.ebay.nl/itm/290569896247, 'any hinge pins spacer' won't work as you have no thread to mount the ball connector and the servo horn. Would be a nice option for Exotek to sell these threaded spacer in 6mm as I couldn't find one at the big hobbyshops.
#6975
