NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#6856
5.5T setting
Any suggestion for setting for 5.5T (novak copy) with HBW 211 software?
I m using 8.6 ratio with punch 6, boost timing 10. no turbo timing at all. Track has 330feet stretch. Felt a bit slower than the rest. Temp 64 degree.
#6858
What is the hobbywing equivalent to the tekin rs? I'm looking to run boost and be able to switch to stock spec [blinky] when needed. thanks
#6859
hobbywing extreme stock 60amp
#6860
#6862
#6863
Originally Posted by COBRARACING
the 213 was only a proto and was never going to be released it was actually designed on the run at the titc thailand
give me a PM with your email address and I will send the 2 files to you.
these 2 files are the files that you will need to replace
'CAR_ESC_settings.db3' and 'CAR_ESC_version_control.ini'
which are the 2 files in your hobbywing usb link folder. then just re-load the firmware to your program card and the 213 will be available to download to your esc.
i have not actually tried this as I have been happy just using the old 1224, but have been keeping all versions of the usb link software ever since the xtreme stock came out.
#6864
#6865
#6866
#6867
Hi guys
Just to let you know and keep you updated i have no accurate date for the v3's release factory is changing the date all the time so i will not comment on it anymore as it is not fair on you guys .
thanks .
thanks .
#6868
The turbo firmware will be available soon to whom runs 1/8th scale buggies and short course trucks .
thanks .
thanks .
