NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#6811
Hi All
I posted the question below in the off road section but no one seems to be able to chip in so thought i'd try this thread
Im having a problem with my EZrun 5.5 combo that has upuntil this point always ran cool as has the motor, its running in 1/10 buggy and has been running fine until the last couple of meetings where it keeps cutting out after about 4 minutes to 5 minutes and means i dont finish the heat. The motor and ESC now feel warmer than before even though the wether is colder.
Its not thermalling as the green LED isnt flashing and after about a minute it will work again or sometimes if i spin the rear wheels by hand. Its amost like its failsafe mode as the steering is still working ok
I've tried rebinding and resetting and stil the same, also differnet radio and reciveer and a spektrum cap but still does it. The battery voltage is about 7.6v when it does stop.
Hav also tried turning off the LVC - no improvement. the only other thing i can think off is if one of the capcitors has gone down but i cant find a spare part in the UK for this.
Or would an external BEC (not exactly sure how this works) be my next option otherwise i have to decide whether to get another ezrun combo or a 60A xerun instead to run with my 5.5 motor
My other question is regarding the Xerun 60a for 2wd buggy. I can afford to buy this version but not the 120a will it be ok with my 5.5t motor in std software mode or i have the option to run an 8.5t sensored motor - if i use this does anyone have any idea of the software version i should use, FDR and what boost, timing and turbo settings would be good.
The track in the Uk we run on has a 40m straight and the 5.5t is fast enough so looking for some settings for 8.5t with boost that would give similar performance.
Thanks in advance
Lunie
Thanks in advance
Lunie
#6813
Software & Settings
post which to use for 17.5 and 2s LiPo in WGT 10 chassis please
#6814
Hi All
Thanks in advance
Lunie
Thanks in advance
Lunie
#6815
#6816
#6817
Hi All
Thanks in advance
Lunie
Thanks in advance
Lunie
I use 119 stock software and boost it up to 40 (without turbo) ... Temps are around 75c on the motor.. runs around the same pace as a 5.5 unboosted.
Give it a go but do a half run and check temps.
Pip
#6818
very sad to see rc city bangkok under water .
#6820
And it could get worst from the latest news, is this your shop Angelo? I thought you were in another Asian country?
#6821
The person who owns the facility is also incharge of the rescue relief plan in Thailand as he is a minister in the government and his son who's dream was to build this facility passed away 4 months ago he was the chief of police .
My self im based in Australia but 4 months of the year in china
#6822
No olly our hobbywing distributor has a shop at rc city the shop you see in the photo with the orange wall but all the guys from Thailand who race rc cars at titc and own stores we are one big family and it's sad to see this happen to The Thai people .
#6823
Give them our best if you get in touch man.
#6824
13.5T TC Setup
hi all has anyone got a setup for the following
Teams powers 13.5T copper can motor
24 meter lenght track indoor
software on esc v3.0_110930 stock
setup so far
MOTOR: Teams powers 13.5T copper can
FDR: 6.9 on 64dp
F/W: 930
MOTOR TEMPS: 165F
RUNNING MODE: FORWARD/BRAKE
DRAG BRAKE: 5%
VOLTAGE PROTECT: 3.0v
DDRS: LEVEL 9
BRAKE FORCE: 100%
REVERSE FORCE: 100%
INITIAL BRAKE: Drag Brake
NEUTRAL RANGE: 6%
BOOST TIMING: 64
TURBO SLOPE: 18 UNITS/0.1 SEC
OVERHEAT PROTECT: ON
TURBO TIMING: 0
BOOST START RPM: 5000 RPM
TURBO DELAY: OFF
TIMING ACC/SLOPE: 500 RPM/UNIT
I can only about 0.5 sec of each lap of the leaders, i went round the track with them while racing and noticed that they get good pull of after slow corners.
Any help would be great thanks and good racing.
setup so far
FDR: 6.9 on 64dp
F/W: 930
MOTOR TEMPS: 165F
DRAG BRAKE: 5%
DDRS: LEVEL 9
BRAKE FORCE: 100%
REVERSE FORCE: 100%
NEUTRAL RANGE: 6%
BOOST TIMING: 64
TURBO TIMING: 0
TURBO DELAY: OFF
#6825
XERUN-120A in Blinky
Ive been a Hobbywing fan for a few years now, started with the Xerun 80A in my 1/8 buggies and have since expanded it to include all my Aircraft ESC. Absolutely love the HW stuff!
I'm getting back into 1/12 racing and I will only be racing 17.5 blinky mode. I'm looking to get the XERUN-120A 1s ESC. I havent read every post in this thread (yet), but from what I have read;
- That ESC doesnt need a booster or Rx pack?
- To run in Blinky mode I need to download the 508(?) firmware?
Is that still true, or does the most current build have a blinky mode?
What is everyones opinion of the 1s ESC?
Thanks in advance
Thanks in advance
