Like Tree156Likes
Futaba 10PX
Old 08-08-2022, 01:15 AM
  #211
Roelof's Avatar
Originally Posted by FolioHattu
Be sure to use R404SBS-E under the following conditions.
  • Use in EP (Electric motor) cars. NEVER use the R404SBS-E in GP (Engine) cars.
Can you explain it why?
It is just an antenna thing. The E-receiver has a small antenna close to the chassis (metals carbon etc) so can (not saying it will) loose some signal on longer distances.
Roelof is offline
Old 08-08-2022, 01:23 AM
  #212
I don´t know why. That is copy paste from receiver manual.
mrreet2001 likes this.
FolioHattu is offline
Old 08-23-2022, 12:17 PM
  #213
My transmitter has stopped working after failed screen calibration. There is no response on the screen and I cannot access the menus. I've tried to update to the latest software version using an Micro-SD card but it did not help. I'm aware others have had the same weird problem - but is there a solution? thanks
tlghome is offline
Old 08-23-2022, 12:59 PM
  #214
R/C Tech Elite Member
mrreet2001's Avatar
Originally Posted by eR1c
I pulled the plug and got the 10px, I have to say this is a nice upgrade from the 4px (which is what I was using).
Curious, the instructions say you can charge a "LiFe" battery from the "Special Futaba Charger Chord". Yet no where can I find what the part # is to the "Special Futaba Charger Chord". Anyone know what external chord/charger cable can be used to charge a LiFe battery via the plug on the backside of the 10px? (id' like to charge w/o haveing to open my battery tray).
OR if anyone know if there is a 3rd party lipo/charge induction pad available that would work too.
thanks,
If it work like the older models it won't balance charge them. I just pull my LIFE batteries and charge them at the beginning of the day or the night before.
mrreet2001 is offline
Old 09-16-2022, 08:48 AM
  #215
Default 10PX Battery Tray dimensions
Hey guys, trying to choose the most ideal 2S lipo for this beast and would like to confirm how much battery tray space we have to work with.
If anyone could confirm the battery tray dimensions, it would be greatly appreciated.
Much Thanks,
MH
mhavlena is offline
Old 09-16-2022, 09:39 AM
  #216
Roelof's Avatar
You could try to find the dimensions of an original battery.....
Futaba Transmitter Battery Li-Po 7,4V 2000mAh T10PX,T16iZ (LT2F2000B) | EuroRC.com
  • Length: 80mm
  • Width: 46mm
  • Thickness: 17.4
Roelof is offline
Old 09-16-2022, 09:47 AM
  #217
Thanks so much, I've been looking for those dimensions for quite some time now...
What about the following Protek 2S Lipo:
https://begoracing.com/shop/index.ph...roduct_id=2015
Dimension (LxWxH): 99.2x31x17.9mm
Can anyone confirm that this would fit the 10px? Seems a bit long...
Much appreciated folks!...
mhavlena is offline
Old 09-20-2022, 06:27 PM
  #218
Regional Moderator
disaster999's Avatar
From the manual, it will fit their LiFe battery as well with a dimension of L86.5 x 39 x 16 mm
https://www.eurorc.com/product/14231...fe-66v-1700mah
the protek battery you found may or may not work. at first glance its too long and thick. If you have the transmitter just measure the void in the battery compartment on the transmitter to get a better understanding
disaster999 is online now
Old 09-20-2022, 07:26 PM
  #219
This is what I use in my 10px.
https://www.amainhobbies.com/protek-...k-5188/p165091
malkiy is offline
Old 09-24-2022, 07:28 AM
  #220
soulcoma's Avatar
Trader Rating: 47 (100%+)
Would someone put the 10PX on a scale with the Battery in it? Trying to see what the weight difference is with the 7PX, M17, and NB4 I'll weight the new RadioLink RC8x when I get it in.
soulcoma is offline
Old 09-24-2022, 07:36 AM
  #221
Roelof's Avatar
The weight of the transmitters is noted in the manuals.
But you want the weight with a battery. Which/what battery?
gigaplex likes this.
Roelof is offline
Old 09-24-2022, 07:48 AM
  #222
soulcoma's Avatar
I don’t have a 10px so I can’t research And I’m not sure what battery fits it. Was just thinking one that owned it could put it on the scale for 10secs and get the weight
soulcoma is offline
Old 09-25-2022, 03:06 PM
  #223
i got 541 grams. that is with the Futaba battery
soulcoma likes this.
Davv is offline
Old 09-26-2022, 09:10 AM
  #224
soulcoma's Avatar
Thank you very Much. It’s a good deal lighter than the 7PX
soulcoma is offline
Old 10-06-2022, 04:53 PM
  #225
Seems like some things indicate the 10Px comes with both the regular and large wheel other things make it sound like it only comes with one anyone confirm
RevolutionM is offline
