Hudy Break In Bench
#46
Looking for some help and/or suggestions. I have the Hudy break in bench and have used it many times without issue. The last couple times I have used it, the motors have been hard to start. I use a Hobbico Torqmaster 180 to turn the prop. I have checked many things and I feel like it's either the Hobbico has lost power or maybe the rubber insert has lost its grip. Any suggestions or ideas would be greatly appreciated.
#47
Is the starter just stalling, or is the rubber slipping on the prop ?
Also are the engines the same brand as you have been running in before - or different ?
There is a huge discrepancy in the "tightness" of new engines from make to make.
I'm guessing your pre heating the engines before starting ?
Is it possible that whatever you are using to heat the engines is not working properly anymore.......
Not properly heated a new engine will be a struggle no matter what starting system your using.
#48
Heat up the engine before the start.
#49
Any one who stil uses this method?
Or is it only oil bath break in?
#50
Spinner (propeller locking nut)
Hi hope someone can help.
The spinner (nut) that secures the propeller to the crankshaft keeps coming loose. I'm using a crankshaft locking tool so at time of assembly it's tight.
I'm using an electric drill with a max rpm of 2000 (in reverse).
After a lengthier bursts with the drill (5 secs) the spinner comes loose.
Anyone experience this? And more importantly what did you do to correct.
Thanks in advance.
Thanks in advance.
