Team Magic G4
Old 06-11-2007, 12:37 PM
  #7081
So....I finally got to race my G4 for the first time. What a great car!!! Using the box stock set up with only light changes to the droop I won all three qualifiers and finished 3rd in the A main. Sadly the A main was mine for the taking but with only 40 seconds to go & a 2 lap lead on the pack that wimpy little 800mah battery pack gave up the ghost and relegated me to 3rd. All in all I walked away very happy with my new ride.
GBagRacing is offline
Old 06-11-2007, 01:14 PM
  #7082
razzor's Avatar
Thats good to hear
With teh 800/900 packs that come with the car id suggest putting it on charge in between heats or after every second heat.
Alternative is to shop around the ectronics stores for the largest capacity AAA cells you can get and make a new pack.These days you can get 1000mah and even the new 1100mah AAA cells.
razzor is offline
Old 06-11-2007, 02:22 PM
  #7083
ALG
Originally Posted by gansei
yes tire shore!!
i started front 40, rear 40.. and tested front 37, rear 37..
But my G4S had much understeer in cornering.
i changed many setup to lose rear grip(Traction)
But rear grip did not lose..
when i turn max steering and full Thorttle..
My G4S did not spin turn........... --;;;
so i changed front 37 rear 40.... then.. understeer was solved.
i learn tire setup is very important and tire effect is big!!!
Every day you learn something,
G4S like to use harder foam on the rear!!! this will also make your wear rate more stable.
Gansei you are learning fast
ALG is offline
Old 06-11-2007, 03:53 PM
  #7084
dnitro's Avatar
When I use the front spool, the car is very stable and doesn't jerk around. The car has a harder time during initial turn in, but on-power is very good. When I put the same shore for front and rear, it is easier to turn and tire wear is pretty identical.
dnitro is offline
Old 06-11-2007, 04:07 PM
  #7085
rmdhawaii's Avatar
What type of track are you running on? Smooth w/high traction? Any traction compounds?
rmdhawaii is offline
Old 06-11-2007, 05:39 PM
  #7086
Kodak Hodak's Avatar
Originally Posted by Krafcik
I AM STILL IN DIRE NEED OF A ONLINE G4S MANUAL. LINKS ANYONE???
there is an online G4S manual i have scanned one i can leave link onhere for all to download or i can post via PM what would you all like G4ers?
let me know
Kodak Hodak is offline
Old 06-11-2007, 06:00 PM
  #7087
Trader Rating: 70 (100%+)
let me know
Just post the link. Thank you!
Krafcik is offline
Old 06-11-2007, 06:02 PM
  #7088
http://doylecrash.com.au/G4SPDF.rar
this will be a tempoary link for a short time so get in fast then ill add link to my BLOG space
enjoy
Old 06-11-2007, 06:56 PM
  #7089
gansei's Avatar
i know that if rear diff harder.. then pulling capacity(Traction Power) is good
in corner-out(on-throttle)..
and i am curious that front diff harder.. Traction Power is good as like rear diff?
gansei is offline
Old 06-11-2007, 07:09 PM
  #7090
rmdhawaii's Avatar
Here is some info posted by afm:
http://www.rctech.net/forum/showthre...42#post2917342
Old 06-11-2007, 07:50 PM
  #7091
gansei's Avatar
Originally Posted by rmdhawaii
thanks rmdhawaii..
your knowledgeBase of RC is the best!!!
But i have seen the diff setup article (maybe it is extracted from serpent manual)
i am curious about this words
"The higher the traction, the lighter the diff oil up front, and the heavier at the rear."
can i set front 10000, rear 50000 in the highest traction.?
are there condition that front diff must be harder than rear diff?
gansei is offline
Old 06-11-2007, 08:26 PM
  #7092
bucknuts's Avatar
Also make sure the servo end points are set very carefully to not stall the servo. I use my charger's motor run function as a DC source to see the amp draw, and when my steering or throttle is set to high it pulls 2+ amps and when it's set right it peaks at 0.8 A.
bucknuts is offline
Old 06-11-2007, 08:30 PM
  #7093
bucknuts's Avatar
thanks rmdhawaii..
That is not always true, I have been in some very high traction situations and 50k in the back was too much, the car would loop on corner exit. Switch to 30K and it was hooked up. I heard parking lot traction was hard to find so I went to 10K and it was hooked up on low traction.
bucknuts is offline
Old 06-11-2007, 08:33 PM
  #7094
British Menace's Avatar
thanks rmdhawaii..
No. It means Gansei,
High traction track....front diff oil is lighter. Maybe 40 or 50,000WT and rear diff is heavy. Maybe 30 to 50,000WT.
Low traction conditions. Front diff is heavy. Maybe 100,000WT or solid spool.
Rear oil is light. Maybe 5 or 10,000WT oil.
I hope this makes sence.
Menace
British Menace is offline
Old 06-11-2007, 08:38 PM
  #7095
Hi Ben.
You have a pm.
I'm at work so not sure how long I'm going to be on here?
You getting use to the car?
I was thinking of your set up when I went to St. Louis this last weekend for testing.
The track there is very newly surfaced but very slick. Very little traction. Ended up a very similar set up to your Mentor set up. Thanks for the heads up.
I'll have to look see if my charger has that function for looking at amp draw.........very handy
Menace
