Team Magic G4
#3076
Winter Nats !!!
Winter Nats is coming soon.
TM drivers, Mike Blackstock, Mike Dumas, Chad Phillips and Bobby Flack, are going to join this game.
All the best to them and wish you all enjoy this game as well.
Team Magic Edith
Team Magic Edith
#3077
Hope they will be obliging enough to come on the board and impart some info once they start running the G4S.
If not mistaken Bobby Flack ran the car last year and represented well under the Phenix Team banner.
Wish them all well ,they will have some fierce competition at the Winter Nats.
#3078
Just reading about Gansei's problem above - what is the consensus on failsafes for a pure racing car? I've just installed one on my brand new G4S, but did not run one on my old G4 EVO. Would a failsafe have helped in this situation? Are they considered troublesome on the track?
#3079
i had a similar problem last year. the connection vibrated loose and yes i did have one installed on my car. and i can say it was lightning fast to react. it did prevent a runaway 3 times before i found what was causing the problem. saved me some broken parts and damaging other cars on the track. i run the very small Q world fail safe. works very well.
#3080
A electronic failsafe is great but a spring on the throttle linkage is better especially if you lose powerfrom a broken wire or contact.
#3081
new battle moive!!
#3082
wide bumper
after Big Crash.. G4S was rebuilded.
#3083
gansei ,why do you run such a long pressure line to the tank ???
Like the head on the engine ,is that the new Team Titan head ?
#3084
i installed chamber(mugen). so pressure line is long for easy chamber install.
after install chamber.. engine response is some mild.
#3085
#3086
Good to know ,you get so many different reasons on the boards.
Gansei .rebuilt the diffs today ,will run later this week .Let you know what a difference it makes.
#3087
Hey guys,
I have a Q about my Reflex and it seems that everywhere else can not answer for me so i'll come here!!
I dont know how to adjust my toe,camber,ride height,caster,droop and car width could you guys point me in the right direction on this please im lost and i race in 3 days!!!!
#3088
....why do you run such a long pressure line to the tank ???
Adjusting the pressure line can give you a litle edge over the competition..
The longer the pressure line, the leaner you can make the midrange as the engine comes to full power.
This is caused by the delay in time it takes the fuel tank to reach maximun pipe pressure.
Keep in mind that this tip should be used as a fine tuning on your motor at the track.
Experiment with different lenghts, you'll be surprised using up to 10 inches of line.
AFM
#3089
Thats interesting ,but whether you have a short line or a long line the engine would still be lean at mid.Can you explain a bit more.
#3090
Originally Posted by T1bobo
Hey guys,
http://www.teamxray.com/teamxray/sho...p?file_id=2525
Its for electric but teh mechanics and setup are still the same.
