Serpent 960.... >
Serpent 960....
Serpent 960....
Old 03-15-2006, 09:34 AM
  #856
captian's Avatar
Originally Posted by C Verano
Captian,
Are you coming to Vegas in April?
Chris
just printed out the race form and going to make some call about hotels to see if i can make it. is any body running white lightining fuel ?
captian is offline
Old 03-15-2006, 09:55 AM
  #857
C Verano's Avatar
Contact Rich Taylor about getting a list of hotels by the track.
C Verano is offline
Old 03-15-2006, 10:53 AM
  #858
captian's Avatar
will do
thanks chris
captian is offline
Old 03-15-2006, 07:51 PM
  #859
C Verano's Avatar
will do
thanks chris
No problem.
C Verano is offline
Old 03-16-2006, 06:37 AM
  #860
C Verano's Avatar
Thumbs up mytsn news
Here some info on the new MF line of motors..
http://www.mytsn.com/news/publ.asp?pid=11650
Here's a link to some team wear..
http://www.mytsn.com/products/desc.asp?prid=4248
C Verano is offline
Old 03-16-2006, 08:46 AM
  #861
mpower is offline
Old 03-16-2006, 11:26 AM
  #862
M7H
M7H's Avatar
Originally Posted by mpower
If you check the pics on mytsn carefully, this is an novamega evo5 just check the crankcase, they filled it up with silicon and printed mf and mega in there.
So this is just cleaned up evo 5. Not very new!!!!
Well, if I compare it to my MAX MX21 MF and to my evo5 (I have both engines), it looks more like the MAX engine, so I disagree with you......
Here, check it yourself....
Evo5:
http://www.mytsn.com/products/desc.asp?prid=2270
Evo5 KHM:
http://www.mytsn.com/products/desc.asp?prid=3153
Evo6:
http://www.mytsn.com/products/desc.asp?prid=3731
MAX power:
http://www.rcmaxpower.com/en/products/motori.asp?id=76
M7H is offline
Old 03-17-2006, 09:21 PM
  #863
C Verano's Avatar
Exclamation Glen
Glen,
Who is coming with you to the Airtronics next weekend?
Chris
C Verano is offline
Old 03-19-2006, 09:20 AM
  #864
Suspended
Jpilone's Avatar
Can someone please post a setup for the Kissimme, FL track please?
Jpilone is offline
Old 03-19-2006, 05:14 PM
  #865
Default JPilone's Last Line in his Signture
Jarrod, just noticed you changed your signature line again.. Ron White is absolutely hilarious! If anyone ever gets the chance, I think his best work was on the Blue Collar Comedy tour.. Oh My God funny!
Darint is offline
Old 03-19-2006, 05:29 PM
  #866
I too disagree. When comparing engines, a comparison of the crankcase alone is not enough to tell you if they are same or not. It's pretty clear a lot of nitro engines, either directly, or OEMed, by Novarossi share a lot of the same parts, including crankcases, carbs, backplates, bearings, screws, conrods, pistons, inner heads, cooling heads, etc. Shared parts are used to realise economies of scale during manufacture and thus keep costs down.
While I'm not an engine expert, to me it seems the major difference is in the sleeve and the crankshaft. Basically, number of ports, where I put my ports on the sleeve, how big they are, their shape, etc seems to have a big effect on performance. Compare a 3 to 5 port engine, a noticable difference. For the crankshaft, how it's balanced also seems to be a performance enhancer. Adding a ceramic bearing or varying the size of the carb venturi are also performance enhancers. Materials too could play a role. Same shape but a slightly different mix of metals to make the case may have positive effect. JP black coats their engine for better performance.
Overall though I believe ports are the major contributor to engine power.
I don't believe the MF is a revamped evo5 even if they shared a similar crankcase.
There's my 2 cents.
going4#1 is offline
Old 03-20-2006, 07:03 PM
  #867
C Verano's Avatar
Jarrod,
The set-up that Salven put on my car at the nats was similar to what Paolo uses at Ft. Myers (http://www.serpent-usa.com/pdf/960_Ft.Myers_Setup.pdf). The only differences are the car at Kissimme was at it's shortest wheelbase,45wt oil all the way around, and the swaybar links on the outside hole of the arm. Also on the gearing I ran a 50-16 and a 45-19. Hope this helps.
Chris
C Verano is offline
Old 03-20-2006, 08:17 PM
  #868
R/C Driver's Avatar
Glen,
Chris
Chris
I'll be racing the Airtronics race this weekend are you guys going to be there ?
Lou
R/C Driver is offline
Old 03-20-2006, 08:48 PM
  #869
C Verano's Avatar
Originally Posted by R/C Driver
Chris
Lou
Lou,
I don't think I'm going to run. Let me know if you need help and I'll come by.
Chris
C Verano is offline
Old 03-22-2006, 02:31 AM
  #870
i'm thinking of upgrading to a 960 next season.. today i use and old Serpent Vector 97-99 version. Is this recommended?
Orfeous is offline
