Mugen MTX-4
#5866
Originally Posted by Adim_X
I am looking to get a new engine for my mtx4. I dont want to drop 500 on a engine. I would like to spend anywhere from 150-350. What would you guys recommend? Hows the Murnan mod OS TZ 3 port? thanks
Maybe a Murnan Sirio could be your ticket for a scary ride.
#5867
Originally Posted by Corse-R
Seen some time ago, people still want to have a big gap on their 2 speed shoes just to have a more violent 2nd gear engaging, 99.9% of those people stripped 2nd gears (the other 0.01% is about to...). I put more than 40 litres of fuel thru my car (still have the 3mm stock chassis) and haven't stripped a 2nd gear.
What I'm doing for not stripping? Easy: adjust the shoes very close to the endbell (the gap on my second gear is about 15/100 of a milimeter - measured with a feeler gauge). And of course, a correct meshing (remove the 1st gear just to mesh the 2nd and then reinstall the 1st gear spur).
#5868
Sirio (Stock or STi), with the new Sirio pipe... adjust the ratios to a little short one (hint: To really make it scream, maybe you need a shorter pinion cluster on your MTX4).
#5869
the gap on my two speed shoes are to the book and if you tune your motor right it works fine,for me anyways.
#5871
If you are considering an OS TZ.12 you may want to look at a STS D3R, i run one of these and eat the TZ down the straight, and it's getting quicker as i run more fuel through it. It is not a competition motor like a JP, EVO3, or Nova, but plenty good enough for our club level racing, and heaps cheaper than the OS.
#5873
Originally Posted by Slo-MTX4
How many of you guys run the 24t pulley?
And have you had any issues with the side belt coming off?
Cheers Daniel
Cheers Daniel
#5874
I run the rubber side belt and the front and back belts are the stock kit ones. If I run the rubber belts on the front and rear I only get about 20 minutes of running on them before they break. I get Days and days out of the rubber side belt. I have not had any issues with the side belt coming off. I use the 25t side gear.
#5876
Hi Guys...
Any idea thats the difference between the novarossi plus 12-C and plus 12-CT ? Thanks... and any hobby website selling them that do ship overseas ?
#5877
versions???
i was just about to confirm my order with RCmart.com, when i noticed that they note (version 1.1) on the MTX4 kit they sell.
I've placed my order on hold, until i find out whether or not there are later versions to the MTX4.
Can anyone shed some light on this.
Thanks in advance.
Thanks in advance.
#5878
Thanks in advance.
Thanks in advance.
I know Mugen does running upgrades/improvements to their parts but I've never seen them give the kits a version number.
#5879
plus
Originally Posted by Bad Mika
Hi Guys...
#5880
