Kyosho v-one rrr
#9766
I been racing it thru out 08, and race with Evo WC, Evo 2. All i can say it my RRR Wc still holds as well as with all this newer kit
ya man...if i have the extra cash, will get one too
Good to heard that, but for me, i still perfer to use spool as i too lazy to change diff oil for front...
#9771
hi guys,i want to know the differences in the rrr and rrr evo shocks.
also if i can use the evo springs in my rrr.and if they better [progressive]
thanks.
thanks.
#9773
does any one know thw answer guys????
#9779
Clutch setup
Hopefully one of you guys can help me. I just got the 2D clutch and a new JLR Tuned engine. I was breaking the motor in yesterday and it's starting to make serious power. So much that when the clutch engages, my car over shoots the turn and the motor isn't even race tuned yet. What can I do so that it's a smoother engagement and controllable? The clutch is setup per the instructions. Softer clutch spring? 3D clutch? Halp!
#9780
The 2D clutch is supposed to be smoother then the 3d clutch, so you most likely have the nut on to tight set it back to 0.3 as per the manual and work your way out for smoother clutch engagement or if still to much then check and make sure that the actual clutch is moving on the clutch bell smoothly chances are you have some grit stuck in there.
Your next step would be the spring...
