Kyosho v-one rrr
#6676
Anybody got a picture of ti bit fitted tot he RRR?
http://www.rc-union.com/product_info...oducts_id=6608
Cheers
Cheers
#6677
Originally Posted by AHP
Hi, all!!! thanks for the instant reply!!!!!!!! I am using the super grease but it seems like it all disappear after a while.... anyway thansk alot!!!! So have you guys heard on the RRR EVO???? this is a great thread!!!!
#6678
Cheers
Cheers
#6679
Cheers
Cheers
#6680
Originally Posted by maskedrider
One question, what's with the pics of the Serpent?
#6681
- Those are great photos. Good composition and lighting .
- I hope the RRR EVO makes a good showing! I'll guess we'll know by Sunday/Monday.
- I bet the RRR EVO doesn't come with that screw set!
- Anybody have a real sheet of Kawahara decals they can scan into their computer? I can use that little sheet that's posted, but the real thing would be good.
- I really like the white/yellow/purple/forescent pink paint scheme in these photos: Photo1 Photo 2
#6682
Originally Posted by antoine80
Hello again,
what oil do you use for shocks? i use the default oil that came with my kit (RRR), what is the difference in handling using thinner or hardest oil?
i change the rear differential oil from 30000 to 20000, i read the tip in the thred, now the car runs much better in the circuit i use to run
my main problem this moment is when i try to change car direction with a lot of spead, it seems like the fron side of the car doesn't "listen" very well.. and the car goes straight i tried to make the rear antiroll bar a bit hardest but it hasn't helped that much. any ideas?
antony
antony
What shore tires are you using? Right now I'm running 37 front and 40 rear and I really like the way the car handles. Also, what setup board are you using and what are your camber and toe settings?
#6683
I think I finally found the rear +2mm offset wheels that I've been looking for! You guys ever try these tires???
http://www.precisionrc.com/nv/car/pr...me=power+tyres
#6685
I thought it was better to run the thrust bearing without grease? It's too easy for dirt and grit to get in there - turning into accelerated wear.
#6686
#6687
I've ordered from that place before, great prices but shipping takes forever. If you opt for the faster shipping it costs a lot more, but you should have it in a week or so.
#6688
#6689
Originally Posted by carkillaii
Im sorry guys im lookin for the o-rings that are used as a failsafe
Hope this helps, Mike
#6690
Those bands work out great!
