Kyosho v-one rrr
#5686
3r
zoom zoom zoom
#5687
ok
the TRACK THIEVES are comming to a track near you and they mean business
#5688
hi marc your bodies are ready. i will ship them out tomorrow.
#5689
Nice painting JGO
#5690
Hello racers, i read Josh comment on the new V1RRR shimo chasis ( the one without battery cover). And he said that improved his lap time but doesn't the chasis heavier than the original one? Is anybody here has experience using it? Thanks for the input..
#5691
#5692
Amigo, I have one of the chassis on order and hoping to findout in a couple weeks. With the HIGH traction that the track I run on can have, I would think that the chassis has a little less flex so it would help. Plus I figure since I never remove the battery, what the heck.
#5693
Originally Posted by 710baby
THE GRAPES WHEN IS THE REGION 4 RACE
#5694
#5695
The team I drive for have produced a steel battery plate to add more weight as low down as possible. The plate is about 35g heavier than the standard item. I've not tested it yet, but as it is adding weight low down and central, it can only make things better.
http://www.pro8.de/
Cheers, Mark.
http://www.pro8.de/
Cheers, Mark.
#5696
Mark: Ah, why would you want to add more weight? Everyone else in here seems to want to lose weight. Doesn't the added weight offset the gain in CG?
Perhaps it's the type of track you are running on - i.e. sweeping turns versus tight.
BTW - Would you buy a titanium chassis (VZ228)? A friend of mine said that if he gets his venture capital money to buy a titanium "printing" machine, he would make me one to try out. It is very awesome technlogy Mark. You can take any 3D Model and using titanium power and an electron beam, turn it into a titanium part. You should check it out: http://www.arcam.com/applications/index.asp
#5697
Originally Posted by Grinder
The chassis is probably heavier. I am adding weight to my chassis out of the box to be at 1725 grams with small tires. I will try the chassis soon. It is probaby the perfect combination of stiffness/weight, and lowers the CG. Weight in the chassis is a good thing.
#5698
http://www.pro8.de/
Cheers, Mark.
http://www.pro8.de/
Cheers, Mark.
cheers
Robert
#5699
Okay guys. You know me ..Where can I get this Shimo chassis from? Got a part number?
Thanks!
Thanks!
#5700
Originally Posted by jag
If you do retire, and I doubt you will, I must say thanks for all the help. It's been fun, except for the ride home on Sunday.
