Serpent 710
#6076
Re: Re: Julius' Wing?
#6077
thank you, a wealth of information you are...
#6078
Originally posted by InitialD
I am actually curious with regards to the rear sway bar setting that Julius mentioned in his setup posted on mytsn. He used the inner hole on the rear bottom arm instead of the stock outer position. Also used a much harder rear sway bar setting (mounted on the center of the bar) with no front anti roll bars...
In the end I wanted a little more steering so I decided to put the rear bar back on. Using the inner holes on the arm makes it softer. That way I manange to keep the change from no rear bar small. Then I played around a bit with the position on the bar to fine tune the steering.
It's like the rear roll center spacers. The bottom spacer is a big step and you fine tune with the top. In the roll bar the arm position is a big step the position on the bar is fine tuning.
#6079
Originally posted by GoldFinger
To me , that is lack of front traction but corrected with reducing rear traction.
But lets hear what Julius will said.
#6080
Originally posted by Julius
The wing is from our Volvo body.
The Stratus FRW is a Stratus 2 but made by Frewer. It's very close to the Protoform Stratus in looks and handling. As Protoform stopped making the Stratus tis is an alternative.
#6081
Re: Julius' Wing?
Originally posted by markp27
Julius, what was the wing you were using in your setup - can't find a reference to it on the mytsn site.
Also saw from the www.serpent.at site, there is a couple of new bodies coming out:
170022 Stratus FRW + wing
170023 Loletta
I can guess what the Lolita, ehm , I mean Loletta is, but what is this FRW thing?
Cheers, Mark.
170023 Loletta
Cheers, Mark.
The Stratus FRW is a close copy of the Protoform Stratus 2.1 but made by FReWer. It's a good alternative now Protoform stopped making the Stratus bodies.
I haven't tried the Mazda 6 yet. Probably Rene will be testing it this week together with the Alfa 2.1
At the moment the Protoform Stratus 2 seems the best body.
#6082
I was running without sway bars first. Our track is fast and flowing and running without bars makes the car smoother and easier to drive. On small tracks you'd probably find the response too slow.
#6083
#6084
It's not so much lack of traction. It's more a balance thing.
I can understand that if the car was 705, coz front to rear balance is far already.
In 710, the stock setup balance is quite good. We can point to the tire wear is balance already.
And with no fr sway bar but stiffen the rear stab wouldn't be make the front and rear end of car rolling in very different load ?
Especially when on-throttle, considering that your FR chasis uptravel is very big.
Please educate me for this...
#6085
#6086
Is front droop at 0 too big for uptravel on the 710?
Check the tire dia. and ride height. With that 0 droop and no sway bar the car will be very very lazy in front.
1 thing I dont know was I never ran the car in that cold weather.
#6087
Comparing to +2.. yes!
#6088
Hi guys, I am being stoopid Will this 801345 fith the S710? It is the stainless brake disk
http://www.mytsn.com/products/desc.asp?prid=2345
#6089
Sorry if this has been asked before but the tires that come with the kit, what shores and sizes are they?
#6090
