Serpent 710
#5311
Here you go....
If you picture your S710 is on my ex-NTC3 position, you can spot the S710 rear upright upper pivot ball position is right at those WHITE CASTER LINES area..........HUDY block has a circle opening for you to stick a wrench thru to adjust your upper pivot ball (someone mentioned it is because YOKOMO GT-4 has the same design and pivot ball location same as S710).....but the INTEGY one is solid alum.....
Yes, you can still do that.....DRILL a hole thru the brand new setup station and put some purple paint and make it like stock....that is possible.
#5312
Do you guys think its safe to mount the transponder on the bumper where the 2 holes are located?
#5313
Originally posted by crashed_1
the person close to a serpent.
BTW, watch your ass at the track tomorrow morning !
#5314
Originally posted by Rookie Solara
Here you go....
Here you go....
#5315
Master D...........GOOD MEMORY....wow, what is that...? P4 with 4.0 Ghz in your head? ....just 1 more time, it is a GOOD setup station, but if you are planning to buy a new one, HUDY will fit 710 better cause Integy one are UNIVERSAL, just not for S710.
My memory is selective though... I only remembered that you had a Impulse PRO on that setup station !
#5316
I did mine.............only thing left is a real head on to the board and some real crash to test out the bumper.
#5317
Thanks for the pics Your work table looks clean. I dont think I will drill a hole, it wont look as clean. When adjsuting the camber is it possible to rotate the the thing around to a point where there is a space to stick in the tool without removing the wheel nut everytime? By looking at your avatar you must be Korean?
Ah no, you cannot ROTATE the block, you don't want to rotate that block and stick a wrench thru the block to setup camber, because the old reading will not be correct....even though I try, the 710 upright is just too high that is no way you can get your wrench to reach that.....DRILL a hole is your only option. And again, only tool you can use to adjust the rear camber and with the setup block is the Serpent given black allen wrench, trust me, still work fine.....just not so professional.
No...I am not Korean, but she is the World-CUP 03 model...she is HOT, no other reason, I am originally from HK (chinese), just like the biggest American IDOL WILLIAM HEUNG......LOL
#5319
HOw has the tire wear been on the 710 on prepared and unprepared asphalt tracks?
also what shore has been working fr and rr?
Also-more specifically-has it been wearing front or rear pretty evenly-or all front or all back. And this is in 5 minute qualifers and 20 minute mains.
Thanks for the answers guys,
Ray
Ray
#5320
And do you still remember the 4mm carbon fiber chassis for my Impulse PRO..? I still have that...
#5321
Depends on HOW you crash your car and how BAD did you crash it....Serpent designed that 2 holes for only 1 reason - like you said, for the AMB personal Transponder.....
#5322
Thanks for the tip Solara. Hey did you guys check out this guys car? He modified the bumper the way my friend did! I like the way he did his rear sway bars.
http://www.mytsn.com/publ/publ.asp?pid=9680
#5323
#5324
initialD-thanks for the info. I am lost in 200mm sedans now. I ran a NTc3 in 2002 and uneven front to rear tire wear was a big issue-but back then the ntc3 could do circles around the Impulse-but the Impulse was a better long main car.
This 710 looks really good.
Ray
Ray
#5325
Originally posted by InitialD
Michael Salven mounts his below the upper bumper brace so it's hidden. I think he made cut outs in the foam bumper to fit it in.
