Serpent 710
#5161
Re: Rene Cornella's 710 Setup in Brazil
Originally posted by InitialD
For those who are interested in setup with a front diff on the 710, here's Rene's recent setup also posted on mytsn;
Suspension geometry Rear:
Downstops: 8mm
Set-up ride height: 6mm
Camber Left: 2.5 degree
Camber Right: 3.2 degree
Toe-in: 1.5 degree
Track-width: 200
Roll-center position upper: low out
Roll-center position lower: low
DRS arm position (low-mid-up): level
Downstops: 8mm
Toe-in: 1.5 degree
Track-width: 200
#5162
"If there is more grig, i will turn to oneway." What does grig mean?? Hey "D", do you find the shocks leak on the 710 because it only uses one oring or is it OK?
#5163
Has anybody used the "Pro Wheel Axles" #801214 for the 710? Does the lighter rotational weight make a difference? Are they as durable as the stock axles?
#5164
Re: Re: Rene Cornella's 710 Setup in Brazil
Originally posted by spawn
camber right 3.2 degree?? my setup station does not have such accuracy, does the hudy setup station or others have such fine markings?
But then I just realised that Team Serpent drivers measure their ride height using calipers and sometimes you'll see weird decimel places !
#5165
#5166
#5168
I have had a set of the spring steel axles for two years, and they still don't show any significant wear.
#5169
[BDepending on how you overfil the shock, you would have some leak out. I find that mine does that in the initial stages when freshly built and then it stops leaking after that. [/B]
For comp. body use .1mm thickness. For alu. body use .2 - .3mm in rear and .1mm in front.
Now we were talking a consistant damper action.
Tip: replace o-ring, everytime you rebuild the shocks.
#5170
So for the plastic shocks run a .1mm shimm on both front and rear? Where can I find these 4x6mm shims? Also where can I find spare o rings and how often do you rebuild your shocks? Thanks.
#5171
With stock axle(710) after 1 - 2 gallon, it will worn out, you can swap it left and right in front so you had extra 2 gallon before replacing it with Pro one.
#5172
Anyone near Atlanta (or anyone that feels like a drive). My home track will be hosting the First U.S. Serpent/Xray on road challenge next month, April 16-18. All makes of cars will be welcome, and I will have (and post) more info soon.
Ralph Burch, Jared Scott, and Josh Cyrul WILL be racing in this event!
www.tfbraceway.com
www.tfbraceway.com
#5173
- spare Oring , SER-909407 Shock o-rings purple+shims(4)
- shims TA-53586 Tamiya,4mm Shim Set, 01,02,03(x10), or
TAKE-TT303 TakeOff, 64Max Shim Set, 4x6
- how often? when I loose confident about damper action
usually every 2 race .
#5174
Thanks, where can I find that Tamiya part #?? I've looked everywhere! I've also phoned local hobby stores and they can't find that part #
#5175
