Serpent 710
#5176
what do you mean?
#5177
Originally posted by SupermaxxRich
what do you mean?
what do you mean?
where do u live?
#5178
Sweet, thanks Goldfinger! Just let me know how much you want for shipping and the shims and I can PayPal you. I live in Vancouver BC, Canada.
#5179
#5180
PM Sent
#5181
Re: Re: I'M A PAPPA!!!!!
Originally posted by InitialD
Show the guts and we'll believe ! Else it could very well be another empty box that you picked from the bin !
Ok, I'll post some guts tonight!
Have a prob, though It seems some of my H11 grub screws are missing. I've had to fit some 12mm grub screws which I had spare from my 705 for the downstops I'll have to give the serpent guys a note to see if they could send me some.
But boy, does this thing go together easy!!! No blisters at this point!
#5182
Originally posted by GoldFinger
Find 4x6 shim and put in below the o ring.
For comp. body use .1mm thickness. For alu. body use .2 - .3mm in rear and .1mm in front.
Tip: replace o-ring, everytime you rebuild the shocks.
#5183
Re: Re: Re: I'M A PAPPA!!!!!
Originally posted by markp27
Bugger! You're are just too quick, D!
Anyway, if my memory serves me well, I think you can find those H11 grub screws packed in a separate plastic together with the spring for the carb linkage.
#5184
Spring for the carb?? Does the 710 come with a throttle return spring?
#5185
OOPPS! Carb linkage! I should finish reading everything first!
#5186
You can refer to step 9.7 on page 31 of the manual.
#5187
Re: Re: Re: Re: I'M A PAPPA!!!!!
That's more like it ! Better get it quick ! We'll probably make exemptions for you to post pics before Friday !
Ummm, step 1.3? Those are the upstops screws which are not needed actually. The downstop screws for the 710 front is in step 1.7 on the upper bumper plate.
#5188
wich belts do you guys find wear the most? Front, side or rear?
#5189
The rear belt would last the longest in my opinion.
#5190
how long did you get on that side belt?
