Serpent 710
#5206
jfc_tech
What kind of setup board is that?
#5207
I believe that's just a makeshift template for checking the bodyshell dimensions during tech inspection.
#5209
Yep.InitialD is correct. rcsabah made it for easy tech'ing. can check body height, width, after run height, tail width & length.
#5210
Re: Rene Cornella's 710 Setup in Brazil
For those who are interested in setup with a front diff on the 710, here's Rene's recent setup also posted on mytsn;
Suspension geometry Front:
Downstops: +2
Set-up ride height: 6mm
Camber Left: 1.5 degree
Camber Right: 2 degree
Track-width: 199.5
Toe-in: -2 degree
Caster setting (mm in front): 4mm
Roll-center position upper arm (mm): 2mm
Upstop (mm): -
Suspension geometry Rear:
Downstops: 8mm
Camber Left: 2.5 degree
Camber Right: 3.2 degree
Toe-in: 1.5 degree
Track-width: 200
Roll-center position upper: low out
Roll-center position lower: low
DRS arm position (low-mid-up): level
Shockabsorbers Front:
Springs: red
Oil: 35
Holes: 4 of 5
Cilinder type: comp
Shock-tower position: 2
Shockabsorbers Rear:
Springs: red
Oil: 35
Holes: 3 of 5
Cilinder type: comp
Shock-tower position: 1
Lower shock position: outer
Anti-roll bar front:
Thickness: std
Position: 20 degree
Anti-roll bar rear:
Thickness: std
Position: 2mm
Position on lower arm: inner
Tires Front:
Make: ellegi
Hardness Left: 40
Hardness Right: 40
Diameter: 63
Wear in 5 min. Left: 0.4mm
Wear in 5 min. Right: 0.7mm
Tires rear:
Make: ellegi
Hardness Left: 40
Hardness Right: 40
Diameter: 63
Wear in 5 min. Right: 0.8mm
Transmission:
Pinion 1st: 17
Pinion 2nd: 21
Gear 1st: 61
Gear 2nd: 55
Front axle:
Type: diff
Diff. setting: mid-hard
Rear axle:
Type: diff
Diff. setting: soft-mid
Aerodynamics:
Body: Alfa Protoform
Wing: std
Gurney strip:
Engine and pipe:
Engine: Mega
Version: 2106 MS
Head shims: 0.3mm
Glowplug: 7 TF
Pipe: 2171
Header: 2174
Length: fix
Fuel: mixed
Remarks:
Chassis performance: easy to drive and fast.
Engine performance: good. One of the best engines out there.
Test remarks: Oneway is faster, but differencial is more consistent. If there is more grig, i will turn to oneway.
Perhaps Rene could post some of his comments on why he used what he used.
Downstops: +2
Track-width: 199.5
Toe-in: -2 degree
Upstop (mm): -
Downstops: 8mm
Toe-in: 1.5 degree
Track-width: 200
Springs: red
Oil: 35
Holes: 4 of 5
Cilinder type: comp
Springs: red
Oil: 35
Holes: 3 of 5
Cilinder type: comp
Thickness: std
Position: 20 degree
Anti-roll bar rear:
Thickness: std
Position: 2mm
Tires Front:
Make: ellegi
Hardness Left: 40
Hardness Right: 40
Diameter: 63
Tires rear:
Make: ellegi
Hardness Left: 40
Hardness Right: 40
Diameter: 63
Transmission:
Pinion 1st: 17
Pinion 2nd: 21
Gear 1st: 61
Gear 2nd: 55
Front axle:
Type: diff
Rear axle:
Type: diff
Aerodynamics:
Wing: std
Gurney strip:
Engine and pipe:
Engine: Mega
Version: 2106 MS
Head shims: 0.3mm
Glowplug: 7 TF
Pipe: 2171
Header: 2174
Length: fix
Fuel: mixed
Remarks:
http://www.mytsn.com/publ/publmem.asp?pid=9689
#5211
The most obvious one is the front but my recent experience with the 710 showed that the side one gave way first before the front !
The rear belt would last the longest in my opinion.
#5212
Originally posted by SupermaxxRich
how long did you get on that side belt?
#5213
Originally posted by jfc_tech
OK, i just wanna share my experience on the recent KKIIR'04 race. My 710 outcome.
#5214
This is the 1st shot right after i open the body!
Like they say in F1 (and I can't wait to watch the Aussie GP this weekend), you'd need a Superlicense before you can get your paws in the driver's seat.
#5215
I don't have that problem during the race...i can go to Labuan racers supplier, Mr. Chris Han, or even ask the Brunei Serpent racers.....but the only out of stock part is the body post. Everyone already cut theirs but end up the body is too low to meet the rules stipulated for the race and have to increase height another hole.
#5216
Hey guys, this is more a motor question than a 710 question, those of you with NOVA based motors, what air filters do you use\recommend, as the novarossi carb has one BIG throat, but it has a plastic venturi thingy to make it 5.4mm. I have had a look at the motorsaver buggy .21 filter, will it be race legal (ROAR) do you think?
#5217
The one that I'm currently using is a Motorsaver one but I believe it's made for .12 carbs. I don't know if there's any rulling in ROAR or IFMAR with regards to carb filters.
#5218
Thank you, I am sure I bought one similay D, but it is WAY too small to fit on, it has an 11mm fitting, but it looks like I need a 15 or 16, I will measure it as soon as I get a vernier.
#5219
Yep, MAX P5...damn fast for my hand
lol:
lol:
#5220
Originally posted by cyba888
I have the MAX M5, whats the difference between the P5 and M5? Is yours modified(tuned) by MF? I paid 290US$
For your info, all NovaMax engines are tuned by Massimo Fantini.
