Serpent 710
#4951
Re: Rear traction
Originally posted by crashed_1
Guys, need help.
I've recently changed to a front ball diff. The car now has good steering and all. What's really bothering me is the rear traction of the car. It has NO problems going into turn nor mid corner but EXITING corners the rear just breaks traction. I've done what the "bible" has asked to do accordingly, but it still happens. I can't run a shore softer than 40 coz any softer and the rims would be showing after 3 tanks.(abrasive track).
I tried a stiffer front diff and looser rear but it still happens. Tried 45º front sway bar setting and it only causes me to lose steering but the rear still breaks traction.
Guys, need help.
1. Add more downstop (reduce chassis uptravel) at front.
2. Add outside rear tire camber (more negative).
3. Place all caster spacer in front and lock (100%) your rear diff.
4. Use 1 step higher rear damper and spring. (during testing, I only make the damper more in vertical position)
5. If nothing helps, change the rear roll center. Set it up on your hudy (spooring), which one will make more camber change when your car leans.
I'm also very upset with the quality of the spurs. I'm using 16/22 and 60/56. 2 sets of spurs stripped in 2 heats. Final heats decided to change the pinion back to 17(which is stock) and the problems were gone. It also happened to a fellow 710 driver.
#4952
Re: Re: Re: Rear traction
Will do. It's really bothering me. The rear traction thingy. Never had these problems on a one way...but driving a one way for me is close to impossible...
#4953
Yes, not to mention higher tire wear in the rear when you run harder rear diff setting...
#4954
Originally posted by InitialD
Perhaps I'm wrong but wouldn't this make driving very difficult on a low traction track due to a lot of on power oversteer? I think it would be more difficult for crashed_1 to control the rear of the car powering out of the corner with the above setting.
D, I guess his problem is the rear ends is roll to far. But everything could be vice versa.
#4955
Re: Re: Re: Re: Rear traction
Since the tire wear is mentioned very high, I assume the surface is very rough. And with that condition, the traction is mostly high, I guess.. is it crashed ???
#4957
Originally posted by Pit-racer
Anyone using nitro shoes on their 710's? If so which ones do you perfer......shore....0 or +2 offset.
I'll have to do some mod to the rims where the Serpent flanged wheel nut can go in nicely.
Anyway, from what I understand, the offset wheels will only make the rear trackwidth wider. More stable rear I guess with the +2 offset wheels on the 710.
#4958
Super Moderator
I have a set of 40 shore front and rears (0 offset). Not used yet. Probably will put it to use this weekend.
#4959
Originally posted by Marcos.S710
isnt that going to make the car too wide and wont be roar legal?
#4960
I'm going to run a front diff on my car. I run a small tight track with a smooth paved surface that is fairly clean. Do you guys recommend running the stock Serpent setup?? Or something different?
#4961
Re: Practice bumper
Originally posted by clmbia45
Or what I learned at the Winter Nats:
(Edit: I want to correct any mis-perception- I didn't SEE this bumper at the Winter Nats- I LEARNED that I needed it there.)
I tested out the bumper today. Had several side brushes with the wall, and no damage. One quartering right front impact bent the bumper down, but no other damage. Had a severe mental glitch, caught the right front tire on the inside of the turn, full power, broke the wheel, pulled the pivot balls out (both bent) and broke the steering block, but other than being bent, the bumper was not damaged, nor was the body mount plate (the upper bumper plate). I noticed no adverse handling effects, and it clearly reduces front end damage. Unfortunately, it is not ROAR legal.
#4962
Hey "D", where do you find the "Reference Giude" on MYTSN website? I can't find it there?? Your link worked for me the first time you posted it for me but now I can't get it to work?
#4963
Suspension geometry Front:
Downstops: 1mm
Set-up ride height: 6mm (Actual ride height !)
Camber Left: -2.0 degree
Camber Right: -2.0 degree
Track-width: 199mm
Toe-in: -1.0 degree (Toe-out)
Caster setting (mm in front): 1mm
Roll-center position upper arm (mm): 4mm under
Upstop (mm): None
Suspension geometry Rear:
Downstops: 8mm
Set-up ride height: 7mm (Actual ride height !)
Camber Left: -3.5 degree
Camber Right: -3.0 degree
Toe-in: +2.0 degree
Track-width: 197mm
Roll-center position upper: outer (UBO)
Roll-center position lower: low (LB)
DRS arm position (low-mid-up): Up
Shockabsorbers Front:
Springs: yellow
Oil: 30W
Holes: 5
Cilinder type: composite
Shock-tower position: 3rd hole
Shockabsorbers Rear:
Springs: yellow
Oil: 30W
Holes: 4
Shock-tower position: 1st hole
Lower shock position: outside
Anti-roll bar front:
Thickness: -
Position: No Anti Roll Bar installed
Anti-roll bar rear:
Thickness: standard
Position: 3 mm from the end of bar
Position on lower arm: outside
Tires Front:
Make: Ellegi 6 spoke (Serpent)
Hardness Left: 35 shore
Hardness Right: 35 shore
Diameter: 64mm
Wear in 5 min. Left:
Wear in 5 min. Right:
Tires Rear:
Make: SpeedMind Dishwheels
Hardness Left: 37 shore
Hardness Right: 37 shore
Diameter: 64mm
Transmission:
Pinion 1st: 16T
Pinion 2nd: 21T
Gear 1st: 61T
Gear 2nd: 57T
Front axle:
Type: Locked to solid axle
Diff. setting: Locked to solid axle
Rear axle:
Type: adjustable diff
Diff. setting: light (when hot)
Aerodynamics:
Body: Protoform Stratus 2.1
Wing: Standard
Gurney strip: -
Engine and pipe:
Engine: NovaMax 5 port
Version: P5
Head shims: 0.4mm
Glowplug: 6TF
Pipe: Team Magic (7 mm inline)
Header: Thunder Tiger (long manifold)
Length: Approx 108 mm
Fuel: 25% Tornado
I used 37 shore front and 40 shore rear and the car behaved about the same too.
#4964
http://www.mytsn.com/products/desc.asp?prid=3293
Click on the Downloads section. You will see 9 files for download. One of them is the Reference Guide (887 kb).
#4965
How come you run such a tight track width "D"? Also why do you have 1/2 a degree difference in camber on the rear and not the front? One thing I see on alot of setups posted by pros is that they will run 1/2 degree more or less on one side of the car? Why is that?
