Serpent 710
Old 11-02-2004, 12:55 PM
  #18391
markp27's Avatar
Default Re: Re: Re: Re: I`M IN THE WINTERNATS!!!!!!!!!!! ! COOOOOOOOOOOOOOOOOL!! !!!!!!!!!!!
Originally posted by 840918001
Hi Mark,
Wath will you do?
Try to hit the other drivers, or slow down to give micheal a change to catch up with you
Thomas
Thomas, , really you shouldn't even have to ask.....the Ring, my boy, the Ring!
markp27 is offline
Old 11-02-2004, 01:03 PM
  #18392
Suspended
Default Re: Re: 125.00 FRO V12 RB CONCEPTS
Originally posted by Sow&Steady
Choco, you can only tell once its in your hands.
Four tanks at the wrong settings can cause an engine to perform no where near its designed performance band.
Buying second hand engines is always a risk you take.
thanks ...choco i think i will pass on that engine...
SERPENTFREAK69 is offline
Old 11-02-2004, 01:15 PM
  #18393
Sow&Steady's Avatar
Default Re: Re: Re: 125.00 FRO V12 RB CONCEPTS
I think that's best. Like I said, unless you can touch it, look at it, twist the crack-shaft and feel for compression, open the rear etc, it's not worth it.
Sow&Steady is offline
Old 11-02-2004, 01:16 PM
  #18394
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: I`M IN THE WINTERNATS!!!!!!!!!!! ! COOOOOOOOOOOOOOOOOL!! !!!!!!!
Oh, don't forget my telescope that you're still borrowing!
Old 11-02-2004, 01:25 PM
  #18395
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: I`M IN THE WINTERNATS!!!!!!!!!!! ! COOOOOOOOOOOOOOOOOL!! !!!
That'll be why you're not finding your way to the track so often these days
markp27 is offline
Old 11-02-2004, 06:27 PM
  #18396
crashed_1's Avatar
Default Re: Re: Re: Re: Re: I`M IN THE WINTERNATS!!!!!!!!!!! ! COOOOOOOOOOOOOOOOOL!! !!!!!!!!!!!
Should've known better...
crashed_1 is offline
Old 11-02-2004, 06:41 PM
  #18397
InitialD's Avatar
Not forgetting the hand wave trick !
InitialD is offline
Old 11-02-2004, 06:43 PM
  #18398
InitialD's Avatar
Default Re: 125.00 FRO V12 RB CONCEPTS
IF THIS NEW ENGINE HAS ONLY 4 TANKS IN IT..AND THE BUYER IS SELLING,IS THIS A GOOD DEAL?CHOCO
What Onkel Sow mentioned is correct. It's a hit or a miss. I would do this if I were you.
1. Take out the glow plug and turn the flywheel. If there is resistance, then the engine is maybe OK. If there is no resistance, don't panic. Either case, go to step 2.
2. Put the glow plug in and tighten it. Put a few drops of after run oil in the exhaust outlet of the engine when you could see the piston covering the whole exhaust port. Try to crank the piston to the top and see if there are any bubbles escaping from the side of the piston sleeve when the piston goes to the top. Should not have any bubbles. Bubbles indicate that the sealing is no good.
3. Take out the engine backplate. Try to crank the engine upwards. There should be VERY minimal play (if at all) in the conrod to crankshaft bushing pin. The whole crankshaft should not move up and down as though the main bearing is loose when you try to crank the piston upwards.
4. Take out the piston sleeve of the engine. Check the top of the piston head if you could see any pitting or rough surface. It should be smooth. The sides of the piston sleeve and the piston should not have any scratches.
5. Also check the bearings in the engine. I would just leave the crankshaft in the engine alone with the bearings in and without the conrod connected and try to spin the crankshaft. The bearings should not feel rough or loose.
6. Check to see if the slide carb barrel can open and close smoothly. Sometimes, the LSN needle and the MSN needle can misalign.
7. Lastly, the crankshaft should be straight. I have seen people sell their engines when their crankshafts bend on an accident. Sometimes, the bend is very hard to detect and can cause a lot of problems with the bearings blowing out.
My two cents.
InitialD is offline
Old 11-02-2004, 07:45 PM
  #18399
Registered User
Pyramid's Avatar
Originally posted by InitialD
The answer is simple. The overhead cost is simply too high. Transportation and handling cost etc. You must remember also that some websites already add VAT which is not applicable if the goods go outside of EU. Something like 19% is applicable in Holland.
Every countries has it own customs `price`, roughly 17.5% here and we still need to cover another 10% sales tax that customer should have paid (yes, they are not) , not to mentioned about 8% additional cost for air shipping (and that original cost is not even a direct from manufacturer). Hmmmm.. I think we really need to check our balance sheet statement... something should went wrong here
Pyramid is offline
Old 11-03-2004, 12:08 AM
  #18400
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: I`M IN THE WINTERNATS!!!!!!!!!!! ! COOOOOOOOOOOOOOOOOL!!
Old 11-03-2004, 12:35 AM
  #18401
Hi,
Allright I know
Thomas
840918001 is offline
Old 11-03-2004, 01:58 AM
  #18402
Ferdi's Avatar
This thread is today 1 year old......
It had a average post count of 50,41 per day
and a average of 873.87 views per day.
Congrats
Ferdi is offline
Old 11-03-2004, 02:30 AM
  #18403
InitialD's Avatar
Congrats
Today? I thought it's tomorrow !
Anyway, congrats. We've come a long way.
InitialD is offline
Old 11-03-2004, 02:44 AM
  #18404
Sow&Steady's Avatar
Congrats
Wow, really?!
I thought it was a lot older than that. I think there's too many old farts in here, err ... I mean MarkP and InitialD of course.
Old 11-03-2004, 08:31 AM
  #18405
Data's Avatar
well, the top three posters account for about 44.3% of the posts. an impressive effort, if the contents of the posts does not matter.
by the way, good job on 3hobby, hope it does not turn into a mini mytsn, we have that already.
Data is offline
