Rc10ntc3
#6586
Do you have the groovy little track width guage? Use that front and rear and then when you want to set the toe in on the rear wheels, wind the front lower pivot ball in so you don't change the track of the car. Track is normally measured with the wheels on so that you know that the car is not over 200mm wide for racing. If you use a +2 offset wheel then you need to wind the pivot balls in by 2mm on each side to correct the track.
#6587
Re: trackwidth
Originally posted by revzalot
I'm just about done with the ntc3. I'm dialing the suspensions setup in but I'm stuck with trackwidth settings. From what ends on the front and rear do you measure track width? With tires on or off? What trackwidths you guys running with the new v2 rear setup?
#6588
hey everyone, i just got a new one way for my ntc3, i installed it, and while taking it out, i realized, that my old front diff was the heavy duty metal geared one, since i had recently taken apart my rear diff as well, i remembered, that the rear diff was still that plastic materiail, my question is this: can i swop my front metal geared differential to my rear? are the diff's even interchangable? with the front one-way and a rear metal diff, i don't think i'd need to service my diff's for a while, so it'd be great if i could. thanks alot!
#6590
#6591
Hey soc123_au
How do you like you BMI chassis? How do you go about cleaning your car, do you remove all the electronics and clean or leave them in there? The reason I ask is I have V1 but only used it once I am planning to use it again the remaining part of our season.
#6593
Originally posted by Z00M
Is the BMI chassis worth the spondoolies over the FT chassis? I was wondering how you go with cleaning as well.
#6595
Can you elaborate more on the BMI? I'm still building mine.
#6596
#6597
Originally posted by cow buster
Hi guys, how does the BMI chasis look like. Currently i have the hardcore racing titanium chasis on my NTC3.
#6598
#6599
InitialD you got any comments on cleaning the car after a race?
#6600
Originally posted by thomasf
has anybody tried the RD logics turbo pipe? I heard that it hits the fuel tank. Has anybody heard of this? Thanks for you input
