HPI R40 Nitro Car Forum
#8941
R40 moving ver slowly
Hi,
Had a slight knock on my R40 over the weekend. After that, even when I full throttle, the car would move at very slow speed. It seems stuck forever in that speed although both the gears look alright from outside. It likes driving your car in 2nd gear all the time. Anyone here have any advice how to check or what is damaged or to replace?
Thanks a mil !
Thanks a mil !
#8942
Try and isolate the problem. Remove the middle belt. Then check if the front wheels roll freeley. If they do, check the rear wheels. It they are free, spin the gears on the 2 speed. Just check one thing at a time, eleminating them if they are okay. If all else fails, start tearing the car down, starting with the area you think is causing the problem.
#8943
I second that, you need to isolate the problem. I would go a step further and make sure that there is nothing else wrong with the car, ie. On some occasions when I or a friend of mine "crashed" our/their cars we would see and fix the obvious problem and then later find out that something else was broken or out of order. This would usually happen during a race and then we would have to leave the race because of this. he he. So, it pays to take your time and be observant.
P.S
Do any of you know where I can get my hands on ceramic bearings for my R40, (individual or set)? Thanks.
P.S
#8944
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
P.S
P.S
#8946
Originally Posted by HarKonnenD
Just how good are we talking about? What's the price like?
they make other sets for the r40...up and down in price.....
http://www.bocabearings.com/main1.as...&n=*20-135C-YS
#8947
Has anyone heard or seen anything about the new R40 yet?
#8948
Originally Posted by fastharry
boca has the best ceramics going..(sshhh..don't tell anyone this great secret for the r40 )
Very large reputable company. Allthough there was better for skates out there, too bad those companies wont venture into bearings for rc cars.
You can also contact really any bearing manufacturer , go through your bearing sizes from the manual and get them to custom make an order for you.
#8949
You would do well just to drop the stock r40 bearings and get some better quality chrome or ss ones, you dont have to necessarily go for ceramic hybrids. In my opinion the stock bearings are pretty poor quality, I switched to some swiss made bearings and the difference was noticeable.
Ceramic hybrid bearings dont offer any weight saving benefits unless you uses full ceramics but I wouldn't recommend for rc model use if you can even find the correct sizes. ceramics allow for higher spindle speeds last longer and run quieter, there really only required for hi rpm applications such as motor bearings, but theres no harm using them in an rc car.
Ai is right the bearings in the r40 are prettys standard sizes, just look around for bearing manufactures or distributors and let them know what sizes you require. stick to European or US made bearings, theres a lot of cheap options made by chinese manufacturers but the quality is questionable.
#8950
i was thinking about changing the engine bearings to highspeed ceramics...but they cost about half as much as a full ceramic set of the entire car...and its only 2 bearings...its the size....right?
#8951
ceramic bearings = good for heat dissipation & longevitiy. Which High RPM = High Friction = High Heat.....so I agree with what your saying on the ceramics.
They also offer ceramic upgraded bearings for some of the REAL WORLD turbo kits I can buy for my car. They are really the only bearing you see in upgrades. Due to the heat factor they are the thing to buy. As well are supposed to help turbo spool up / aka reduce turbo lag.
Also I hear of people replacing just the RC motor bearings with HQ ceramics, because of the high-heat factor.
#8954
The ceramics (hybrids) look great. How about ceramic gears for the diffs. ?? he he, that be great…
#8955
What bearing sets have you guys purchased. Also I just thought about this , would ceramic bearings also weigh less? Are there any bearing sets that might?
I purchased a set for cheap. They look ok quality. Im going to try these out soon. I thought the stock ones seemed alright?
But yeah im probably going to get something from boca very soon. That or maybe acer?
