HPI R40 Nitro Car Forum
#9092
is the R40 as durable as the MTX-4?
#9094
i would recommend the nova rossi nsr12 s3 great power full cheap engine. good for the r40 it is what i have in my r40 cheers
#9095
Originally Posted by HarKonnenD
I'm pretty much close to the stock setup. All I did really was shockpreload, droop settings, and castor setting. Those are the only things I really touched as well as add a few upgrades. All that I'd be getting last is the LW chassis, but before that a new radio would be nice. Now that I have a real car I'd like to save up some more $$ as I'm not working too much now since business is slow. I may end up having to go find a new job because of this. However it's all good. Nothing like more $$. Now I have the CD3 Pro to sell, MGT, and TL01. The R40 and MRX4 stays.
BTW for diffs I'm using the kit setup and the car handles like a dream.
Hi
Please could you tell me your stock setup
Brett
#9096
Originally Posted by Artificial-I
Ill have to try both at the track next time. I also have a Mazda6. Thanks for the tip.
#9097
#9098
Originally Posted by Brett.w
Hi
Brett
Brett
Front toe in/out :0.5
Rear toe in /out: -1.5
Front Camber: -0.5
Rear camber: -1
Front Preload spacing: 6mm
Rear reload spacing: 4mm
F/R springs: Stock
F/R Diff oil: Front Stock/ Rear None.
Shock Oil: Front 50wt/ Rear: 45wt
Rear Droop: 2mm
Castor: N/A
Front/Rear Tires: Spider Foams 26mm 37 shore/30mm 37 shore
That's pretty much it. The rest of upgrades consist of LW 2speed, LW shafts, and now an Ofna CD3 Pro Centax clutch. It really works better than the stock clutch and the clutchbell is designed to allow the shoe to fit in like a glove for maxiumum contact. After lots of running there is hardly any wear and no glaze build up. I don't have a hudy board, but using the clips and a handy caliper helps me along. I'd still like that LW chassis though.
#9099
I do know that the 4 turns in harder than my R40 or my MTX3.
just my $.02
#9100
For my R40 I do have the CF shock towers and those are in the stock setting.
Front Camber: -0.5
Rear camber: -1
F/R springs: Stock
Rear Droop: 2mm
Castor: N/A
Front Camber: -0.5
Rear camber: -1
F/R springs: Stock
Rear Droop: 2mm
Castor: N/A
#9101
Yeah No oil in the rear. I however did use some of the front diff oil to lube the rear gears though. That's about it. The rear end stays firm and never whipes out. When I mean never...I mean NEVER...providing you have the right tires for the surface.
I may be purchasing the DX3 radio for my ride. I think I'd stay with the nitro sedan for quite sometime before running the 8th and infact...may even sell the 8th. For the moment the radio does has all the basic functions I need and it is spektrum. Surely there is the M8, 3pk, but why bother if I'm hardly racing hardcore? Ebay is an option, but I'd hate to get a used radio system.
#9102
Originally Posted by Jea3
I haven't driven the 4 enough yet, but is the R40 as durable as the MTX3? Not even in the same club. The MTX3 is one of the most durable pro level cars out there.
just my $.02
just my $.02
#9103
i can get the MTX-4 for 395$ which is less then the Hara Edition by like 100$...so the MTX-4 is better then the Hara Edition or even the MTX-3 PROSPEC?
#9104
true but if it is more durable out of the box...then most likely it will be more durable with hopups plus better handleing and everything else with hopups...dont you think?
im just trying to compair because i dont want to have to upgrade to a better racing car when i need it ...i would rather buy now and be able to use it later and now not just for now.
#9105
my two
