Kyosho V-ONE RRR EVO 2
#362
I don't know if this has been posted or not but anyhow here's the link to the new Evo 2 WC.
http://www.kyosho.com/jpn/products/r...duct_id=104157
#363
One photo shows a rear blade sway bar, the other shows a stock one.
Can anyone translate?
#364
#365
Here are the differences:
●Approximately universal joint (VZW219 and VSW006)
●9mm ball screw hard type
●Rear adjustable stabilizer
●Adjustment rod (for rear adjustable stubby)
●Muffler stay holder (aluminum make)
●Aluminum drive washer
●SP drive belt (front, middle and rear)
●FRP battery plate
●FRP middle plate
●Hollow middle shaft
●Aluminum dress engine mount
●Titanium coating damper shaft (30mm)
●Light/write weight 1st gear housing
●Sealed bearing 6×10×3mm (servo saber section)
Basically just a hopped up EVO2, no chassis/geometry changes
●FRP battery plate
●FRP middle plate
#366
●FRP battery plate
●FRP middle plate
●FRP battery plate
●FRP middle plate
I love how they put the world champion logo on it like this was the car that won, it's almost as funny as Xray being vice champion of everything. Marketing at its finest.
#367
That's the kit to have, the evo wc with the new geometry of the evo2. Not sure why they released both, but I guess there is a market for both cars so they did.
Since it has had the same platform since it became WORLD CHAMPION so many years ago.
Your comment make's you sound like such a dumbass or should I refer to using your old username BRIANHATESNITRO
#368
#369
KYOSHO !! - old video, but it's a KYOSHO !! There are no substitutes ! To be the best, you have to race with the best - Kyosho.
+ YouTube Video | |
#370
Ive got an RRR WC Edition, would I be able to use the new -C spur gears without any problems, or would I need a new shaft, and spur housing??
Cheers.
Cheers.
#372
What ackerman gives you more steering over the stock setting "B".
Basically looking for the equivilent of #12 (as per Josh's tip below)
Servo Saver - #10 is great for if you need a lot of steering and the corners are more high speed and flowing. If you have any tight chicanes or sections where you change directions and the car gets loose then it is best to run a #12. #12 (more ackerman) reduces oversteer in the center of the corner while making the car react a lot faster through chicanes without making the rear of the car step out.
#373
#374
Cheers, thanks
How do you guys keep your 5th body post intact? Mine comes loose after a days racing, or I strip it screwing it in (up to my third one already!)
I was thinking of getting the Kfactory Aluminium 5th Post to eliminate the problem, but it looks too short (anyone using one)??
http://www.rcmart.com/catalog/rc-rrr...c8b783e7378d34
#375
Cheers, thanks
