Trinity G4 - Team Magic G4 E-Type
#1171
I bought my car when they first came out last october off ebay. I'm assuming it was bought before that so it is probably an early production car. I have to mow the grass today hopefully do not hit this dogbone while i'm mowing. I'm figuring its in my neighbors front yard Thanks for the info guys.
i settled for the stealth black grease by associated. If i wanted to order the mugen stuff the min order was 25 dollars. Oh well, it will be good enough for me
I think KMAC is right, i'm running my car a little wide, i like it that way. I should be able to if i want to. Thats why i ordered the Universal joints. It will be better for me.
Thanks,
Mike
Thanks,
Mike
#1172
Mike
Where did you order the universals from?
#1173
shopatron.com they have them in stock. Well there website said they did. I paid 49.99 for them plus i got some other stuff i needed like gear diff case gaskets and the rear body mount posts. I need these parts asap because i can't drive my car now. I can't find the other dog bone, so i only have three If i order another set to replace the rear ones, i hate dog bones, i will definately order them from you.
Do i have to lube up my front one way? If so how do i go about doing that?
Also how do i adjust the clutch nut while the pinion gears and everythig is on the car. I want to make the clutch engage a little sooner than it is and i don't feel like taking it apart again. Can i adjust it without taking everything off??
THanks,
Mike
THanks,
Mike
#1174
Here are some pics of my busted rear shock tower.
Mike
Mike
#1175
KMAC,
I see you made something for the front steering problem. How is that working out? Would you be willing to make me one i would pay for everything? I'm talking about how you drilled and machined those parts on page 35 of this thread. I do not have the skill or the machinery to do this. Thanks,
Mike
Mike
#1176
Budlight
I got news for you. Shopatron does not show in stock counts. I know for a fact that Trinity is out of stock on them. I have a few sets on backorder from them for two weeks now. I am getting them from my other distributor hopefully this week.
#1177
Shoot.... Guess i won't be driving my car for a little while then. Thats ok i should be getting my pocket bike tomorrow. I can put around on that till i get my parts for this car.
Are they ever going to ahve better parts support for this car? Is anything interchangeable with the V-one rr evo?
Thanks,
Mike
Thanks,
Mike
#1178
hey Brightbluehaze
i live in melbourne fla. what part of fla. do u live in the g4 pro e-class is what i drive there are some tracks around there is 1 in lakeland,1 in kissimee called FullthrottleSpeedway it is 1/8 scale track . 1 in orlando , 1 in daytona. i hve the setups i use my eng is a Rody RBx12, with a jp modified crank.
#1179
budlightnmyhand, I also have the early production G4. The front dogbones were causing a problem for me, but i didn't want to pay all that money for universals. I ended up using my brain, lol and i went to my lhs and bought some gs racing shock o -rings, exactly like the blue ones that come with the G4. All you have to do is add one gs ring on each side and the dogbones will have no play. Doing this will center the dogbone in the middle of the outdrives instead of letting the dogbone drop down to the diff outdrive b/c of gravity and cause it to fall out. Hope that made sense and it works, b/c it saved me alot of money. 3.50 vs. 40.00??? What a tough decision NOT. Hope that helps
#1180
RCNUT - do the PMB setup stations come with the board too? What pricing should i be looking at? Thanks
#1181
problem is i already lost the dogbone and can't find it. I already ordered the Universal shafts now its all gravy.
Mike
Mike
#1182
Mike
Mike
bballer
#1183
fitted a set of v one r 3racing universals in my g4, cost me $14 i think, from hong kong
http://www.rcmart.com/catalog/produc...oducts_id=3390
#1184
Instead of the o-rings I cut a short piece of fuel tubing and stuff it up in the drive cups; fits perfectly.
#1185
I did take my whole car apart and reassemble. I bought mine already put together and when i got it, the shocks leaked oil all over the car. So i took it apart and found pieces missing. I made sure to use the little green o rings with the dog bones, i still don't know why that one fell out.
Agg Daddy, if you ahve any close up pictures of your car i would like to see them. I just want to look over it and see if i notice anything about yours that i might have set up wrong. Like i said i'm very new to this and little thing i can learn is a great help. Pics of your suspension setup would be most helpful. I do have an integy setup station but pics would help me out better than seeing number of your camber and caster and toe.
Thanks,
Mike
Thanks,
Mike
I have pictures in several places but they aren't very detailed. Using a low budget camera I guess what I'm trying to say is just make sure every screw is tight and not loose. The standard screw that screws into plastic gets loose after a while. I would replace all of the bottom and front stiffener brace with 3x10 hex screws. I'll try and get a close up of my steering system posted soon.
http://www.geocities.com/aggace/g4-page.html
and here too
http://photos.yahoo.com/aggace
