Trinity G4 - Team Magic G4 E-Type
#1186
What springs are you using??
Mike
Mike
#1187
HI GUY'S
IM FROM AUSTRAILIA I JUST BOUGHT A G4 & MAN IT'S
UNREAL. HAS ANY ONE GOT SETUP,S ?
THANX GUY'S
THANX GUY'S
#1188
Mike
Mike
Blue in the front and green in the rear.
#1189
sweet the reflex springs fit the G4. That is awesome!!! i found those pretty cheap on ebay!!!!!!!!!!!!!!!! YAY
Can you tell i have had a few beers?
Mike
Mike
#1190
I'm going to be running on basically blacktop. The track where i will be racing at will be blacktop also. What shock oil do you recomend i use and what caster, camber, toe do you recommend. What springs should i use. Also should i run rubber or foam tires.
I'm just trying to get a starting point i know my track/car set up will be diff than yours but i just want a basic starting point.
Thanks,
Mike
Thanks,
Mike
#1191
Standard setup sheet will be sufficient to get you around most tracks.
#1192
G4 Standard setup sheet
#1193
bballer
The set up station and board will be $90 plus shipping. They are due to arrive here on Thursday.
#1194
thanks, Ill try to raise some funds
#1195
Guys,
I just read on the powerline racing website that they willbe the US importer for Team Magic and HARD racing.
I guess nobody wants to play with Ernie anymore
www.powerlineracing.com
#1196
powerline
Actually both of them will be carrying parts. I spoke to both companies today and they will both be distributing parts. I would imagine that powerline will be getting more parts than Trinity. I don't think it is a bad thing becuase now I have two sources to get parts for all of you.
#1197
Back in!!!
Hi guys! My name is Jeff I'm from California and I am getting back into R/C racing after being away for several years. After doing a lot of research I've decided on the T.M. G4. I believe this is the best touring car for the money that you can get today! I received it today after ordering it on Friday. My hats off to RCNUTS! (Mike). After going thru the parts today, the quility of the kit is the best I have seen. Any Advice would be appreciated before I start building. I tried to go through this forum but it is way to long! I look forward to chatting with you guys......and sharing info even if mine is "a little old school" ( ;
