Kyosho VoneR Thread
#9811
Hey thanks for the advice Re: "the outdrives" I picked up a set today and ran them already~ much better thanks!
#9812
I am just wondering if anyone can give me the part # for the front outdrives that goes with the front one-way?
#9813
I have the NS3 engine. It really flys. The turbo crank is the same as the NS5 Part No 15615. If your using 16% Nitro reduce the shims on the head by taking out the 0.3mm shim and replace with 2 x 0.1mm shims and use the C5TGF plug.
#9814
What is the best shoer tires to use on this car? I run on a medium sized track that is prepared with sugar water and the VHT...... what would be a good split to use on this also?
thanks
thanks
#9815
#9816
#9817
thanks
thanks
I myself run no split at the moment 40F and 40R but I have used 42F and 37R also have tried 45F and 40R. A safe starting point when I first started useing foams was 40F and 35R.
I see we live in Las Vegas on those really hot days when its 114 outside, I bet the track temp is way up there and its real greasy. Most people will go for a harder tire because of temp, but a good friend of mine gave me a suggestion of trying softer tire to combat the greasy track, and boy did this help out a lot.
So in other words get your self a few sets of ties and see what ya like
#9818
#9819
thanks
thanks
#9820
For 30% Nitro you will need 0.4mm shim installed and use the C6TGF or the C7
#9821
http://shopping.rcmodel.com.hk/
hey i found the G4 side belts but they're not the K-Factory one. Will these work?
#9822
Originally posted by Manticore
the front and rear belts are not necessary. the long side belt makes the difference.
#9823
Originally posted by Taylor-Racing
Aren't you using the SP side belt?
#9824
I use SP belts front and rear and kfactory long belt.
Were you running the R belt/27T pulley?
#9825
Yes, but which side belt were you using before the K-Factory one?
