Xray NT1
#5327
#5330
thanks for info. i did pick up a nova 2652 for the motors.it was the recomended pipe thanks again
#5331
#5332
#5333
Bouncy car
Hi guys need some help
running my car on a medium track, with a 200ft straight, while running down the staight the car seems bouncy and not all that stable
Traction is medium and mostly smooth, running similar setup to http://forum.teamxray.com/xform/inde...1152&setup=nt1
except for using 37f 40r and dark blue spring all around.
Please help qualifiers is tomorrow
Diatta you may recognize this setup
#5334
This is a rookie question, but I am not a rookie, but new to the Xray NT1 2009 vehicle. I am having difficulty getting the clutch set up properly. The diagram in the manual is very understandable, but I can not seem to achieve any clutchbell endplay whatsoever. I know XRAY is known for their attention to detail, but is it possible my clutchbell is machined improperly not allowing the bearings to not be in the proper position? I feel that the problem is something I am doing wrong, but have been unsucessful at figuring it out. My maiden voyage with my first new nitro touring car's race date is getting close (Pete Johnson Memorial at Blue Diamond in Delaware), hope to have it figured out by that time.
Actually, this is all your fault Dorian, you shoulda stayed in our area so I would have a local XRAY rep who could help me with this problem
Any suggestions would be greatly appreciated.
#5335
Bouncy car
#5336
#5337
Hi,
The clutch is the standard and not the high dynamic, correct?
Have you achieved the 9.2mm distance from the nut to the end of the crankshaft as it is specified in the manual?
How much gap have you set? And then the clutch bell touches the shoe?
#5338
Just a thought. Is it possible that the end of the crankshaft has been shortened?
#5339
Custom NT1 Chassis #2
Good results at our small test track with chassis #1.
Here are some photos of chassis #2.
#5340
