LIFEPO4 RX 6.4V BATTERY
#31
Cobra i emailed you 3 or 4 days ago about buying 1 of the hump style packs. My email is [email protected]
#32
I have sent you email
regards Angelo
#35
I realize this is the off-road section and that the dimensions have been posted but I'm just too damn lazy to go measure
So, will these fit in an onroad car in place of a standard 5 cell stick pack? If all the dimensions are the same or smaller it should work fine but if any one of them is larger I don't think it will work.
#37
you are a real gentlemen im hoping to become not the biggest but the best out of Asia thats what im aiming for to be the best quality and have the best Batteries worldwide .
thank you once again Pato you have taught me alot on this forum .
regards ANgelo
#38
Angelo,
I replied to your email and am waiting for info. Thanks!
Matthew Melick
Matthew Melick
#39
Advantages of lifep04 over lipo
no regulator
charge faster 10amp and above
will not catch fire
will not buldge
can take more current
no low voltage cut off needed
longer lasting
ran 1 hour for rc pro series final and the battery only took 600mah on recharge so more than enough for your big Amains
[email protected]
no regulator
will not catch fire
will not buldge
longer lasting
[email protected]
#40
Dear gents
Just an update on the rx packs .The true test was run during the rc pro series down under Australia with excellent results.
The rx pack was run in wayne walkers buggy and after an hour long final and 8 minutes of warm up the 1400mah pack lost a combined 600mah .
so this is a great result for the lifep04 .
#41
pato, avisame cuando te llegan para ver que tal, me intersa usarla en mi mtx4
#43
How about a 800 or 900 mah hump pack size for us weight watchers, since
600 mah lasts over an hour?
#44
is there any development to increase the MAH rating to above 2000mah?
also are they in Australia yet and available to order...
