Tamiya TB-Evolution III
#5521
calling it quits.....
Im about to call it quits on the evo III................ I called tamiya today to order the bumper,one-way gear,bevel gear,main shaft and every part was out of stock and they said they wouldnt have em till maybe next week but wasnt sure........ AHHH !!!!!!!
#5522
Re: Re: Re: oneway gear fix
Originally posted by markp27
V12, what's the min weight here in Germany? My Surikarn weighs in at 1547g fully equipped.
My EVO3 is at about 1510g currently using CS27 or Sorex28 and leightweight JB inserts. This is including the Square gearboxes and Jürgen oneway and a motor fan. Batteries are GP3300. Itīs basically a stock EVO3 not a SL but upper aluminium mounts and everything similar SL but the 2,5mm chassis.
Weight savings are removing the centre brace as the chassis is very stiff using the Square aluminium gearboxes. Also Iīm using Lunsford Ti turnbuckles and some of the screws are replaced by Square Ti screws.
Square aluminium gearbox is about 14g heavier than plastic gearbox so 28g for both.
#5523
thats really good, has anyone gto a Kai chassis?
Evo4 aswel... is it true tamiya are ditching the 415 at the worlds?!
#5524
Re: calling it quits.....
Otherwise I would recommand R10. Sometimes Iīm ordering from them especially when I need some special parts. Very good service.
#5526
@ EVO UK
I think not very much people are using Kai chassis. Looks ugly to me and itīs way too expensive. Something like the Square gearboxes makes much more sense and looks great also.
There is room for speculations always but I have to say I donīt care if Tamiya is using a 415 or any prototyp at the worlds. Itīs the same hype with the 415 as it was with the EVO3 in the beginning.
I donīt like the 415 even if it looks good. I think itīs a pain to work on if you have to rebuild the rear diff or just wanna change the front oneway for a diff. Also I donīt like those excenters for belt tensioning. I had one car in the past exactly build like the 415 in the gearbox area. Never ever.
The EVO3 is working very good now without problems. Very easy to work on also. Why change for any other car now?
#5527
V12 , i like the way you think, i share the same thoughts bout the car and so on.
I brought a Kai from a close friend for about Ģ35 so it was an offer i couldnt really refuse...
i might not even end up useing it, or i may try and build up another evo-KAI out of spare bits for show or something. who knows.!
ill have my square boxs verrrrrrrrrry soon cant wait!! and also the 3 piece prop shaft.
Had no probs with the evo3 for a long time, things just seem to get better and better for me with it.
Are there any ways to increase steering throw as i get to a point were the turnbuckles touches the prop shaft. turning your kunckles over or anythign like that?
thanks
Tarnjit
thanks
Tarnjit
#5528
EVO UK
You will be amazed by the Square boxes. Best custom part I ever saw. Beside the jürgen oneway.
Why are you using that much steering throw? Usually Iīm using 50 - 70 % steering throw. Sometimes up to 85% on a small track but never any more. There are other ways for moore steering.
#5529
well its the track i race on mainly, its got a chicane an hairpins and i was compareing my turning circle to my tc3 driving friend , his was quite alot smaller and i was wondering if i could get more steering to make mine smaller you see.
stop talking about the gearboxs i cant wait no longer im going to cryy!!!!!!!!!
Tarnjit
Tarnjit
#5530
EVO look at a different servo saver if you are using one or a longer arm on the servo if not. Either way you still should not need that much throw you are getting way outside any tires performance range with that much throw. Also if you are using a digital or comp. radio check your endpoints not just dual rate.
#5531
yeah ok at least im not doing anything i was thinking maybe i made a mistake and wasnt getting enough somewhere. im useing a kimbrough mid sized servo saver
#5532
FYI- I've got the Tech 3 piece shaft set, and it's very heavy compared to the one piece shaft.
I just got the Titanium axels and dogbones. Should lessen the weight a bit.
#5533
could you tell if it done any good to the drive train in terms of binding and 1way gear probs?
#5534
and any pics if possible
