Race Opt MTS T2/T3
#151
M-124249 - RAS 49MM SHOCK SET FOR MTS NEW VERSION (2) AUD$39.95
Better fit on all components and improved sealing for the top cap o-ring.
Regards,
Ren.
#152
Hi Guys!!
Somebody have tried the front belt race opt 516 teeth?. The Transmission is looser than 513 with bearing holders (eccentrics) adjusted at minimum.
For my last race I changed the original belt for the race opt and the car was not fine,even the front belt being adjusted to a minimum tension there are moments that are tense.........
Looking into it now why with TP and working ou a solution.
Regards,
Ren.
#153
Location: A step closer to where I need to be a step further from where I was
Thinking about two of these for the Snowbirds, question is will the support be there or has the interest faded away, no activity lately.
#154
If you refer to local, then not exactly too sure how big the US market is on this chassis, Much bigger presence in Asian being locally produced there, and only just starting to get a bigger following in Australia.
Information is a little difficult to find, especially for setups.
I myself am trying to put out as much info as i can, but will be mainly be for low-medium asphalt tracks, Ive modeled the car and been using RC Crew Chief and been trying to work on various things along with learning where the weakness and strengths lie. Just starting to understand some things, hopefully with the newly released springs it will move progression forward. no pun intended.
#155
Maybe it is not interesting anybody, but these RAS shocks are making miracles on pan-car or Formula 1...
You have to try!
You have to try!
#156
There is a really good racer and I think is the local distributor for this car. He will race at the Snowbirds. He is very active in the Florida on road racing scene. Check out dischargerc.com and contact him. He is very vey helpful.
#157
Cool a friend if mine runs it now, and another has or had ties I think. I like what I saw just didn't want to start from scratch if I went to the Birds and they didn't. Good that some others down that way are into the car.
#158
I will indeed be at the Birds this year again! Anything you need, you can email me at [email protected] or PM me on here.
Thank you,
Robert
#159
Cool man I appreciate it....check you PM
#160
Thought id share the modified setup pdf sheet ive done
will be adding also onto petitrc when his server is up and running again, but in the mean time here is a shared link for google.
https://drive.google.com/open?id=0B3...F84b3VBWlJwdGM
#161
Picked up my car yesterday, set up for carpet I really like it so far and looking forward to running it next week, I'll have to get in a spare parts order soon
#162
beginner to on-road looking for a USGT chassis...would you recommend this car for a beginner? thanks
#164
is there a list of the direct fit parts from other companies?
