Like Tree2Likes
Tamiya TRF418
Old 08-03-2014, 01:33 PM
  #1516
I drive outdoor on a technical track, the handling is good, .. but my 418 overturns as soon as I go on the curbs, what would you suggest? I've tried many things already
DPRacing is offline
Old 08-03-2014, 03:06 PM
  #1517
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Well after all is said and done at the roar on road nationals my Tamiya took home 2nd place. Car got much better and a bit more free making it easier to drive. Still needs something as it wasn't perfect but good enough for 2nd. Sadly we only ran 2 mains out of 3 due to rain but it is what it is. Tamiya on the podium
If anybody would like my setup I will be posting it to petitrc probably tomorrow.
xrayaustin is offline
Old 08-03-2014, 03:20 PM
  #1518
Well done! Look forward to seeing your set-up
Qatmix is offline
Old 08-03-2014, 03:33 PM
  #1519
Originally Posted by miguelito75
Try schumacher greens...
They are the same as the HPI silvers.
Old or the new silvers?
inpuressa is offline
Old 08-03-2014, 03:39 PM
  #1520
xrayaustin's Avatar
They're not the same. They may have the same dimensions but the feel is 180 opposite. Trust me
Old 08-03-2014, 03:59 PM
  #1521
d16dcoe45's Avatar
You could try drilling the pistons holes out to 1.1mm. That will give less pack for high impacts like running over curbs and should keep the car more grounded.
You may or may not have to make oil changes to compensate for reduction in damping.
d16dcoe45 is offline
Old 08-03-2014, 11:21 PM
  #1522
I had a hunch about that
Grats on your podium finish
btw, are old silvers supposed to feel softer than the ride reds? anyone?
Old 08-04-2014, 03:37 AM
  #1523
acutts's Avatar
When using Tamiya 42245 Aluminium body adjuster mount do you use the kit body clips as they seem to not want to fit at all
acutts is offline
Old 08-04-2014, 04:29 AM
  #1524
I would try 400 or 450 oil in the rear shocks and raise the rear roll center.
frozenpod is offline
Old 08-04-2014, 06:34 AM
  #1525
xrayaustin's Avatar
To me the hpi silvers are a more consistent pairing usually. Also even though the rates are nearly identical I find that the reds have a more progressive feel and I actually prefer them on a more bumpy track. Sometimes when switching to rides the car has more bite on power but tire wear is very heavy.
It's crazy because the rates are identical but like Schumacher greens the feel is very different and that's what matters. I would stick with hpi silvers. You can't go wrong with them
Old 08-04-2014, 06:52 AM
  #1526
acutts's Avatar
Wish I could get some but it seems they are made of unobtanium and therefore unobtainable lol
acutts is offline
Old 08-04-2014, 07:33 AM
  #1527
Yes. They are a complete asshole to get on.
cplus is offline
Old 08-04-2014, 01:45 PM
  #1528
syndr0me's Avatar
Trader Rating: 32 (100%+)
It remains to be seen how durable they are, but the Yeah Racing c-hubs with the bearings in them (sold separately) are neat. Certainly the smoothest action and least play I've seen.
syndr0me is offline
Old 08-04-2014, 07:26 PM
  #1529
xrayaustin's Avatar
double post
Old 08-04-2014, 09:45 PM
  #1530
jdawg81's Avatar
Admist all this banter about durability. ..
i would like to give an update from nationals. I'm running my car in 17.5 and am still trying a lot of things after the second round. As of now I'm in 5th but should be 3rd (bad blowout in the second round). I have the entire samix conversion on and is much better even in stock for those of u wondering if it would work in stock. The car is very consistent across the 6 minutes. Trying to get the car to run faster upfront currently.
Hopefully after tomorrow I can report back and say that I'm in the top 3 where I feel like me and the car of capable of being. The car drives good and handles great. Will report back later and if I can get the car better I will post my setup if somebody wants it
Were you using the samix conversion on indoor carpet? I was curious to try this conversion but wasn't sure if there was any benefit to using it for 17.5 blinky on indoor carpet.
jdawg81 is offline
