Like Tree2Likes
Tamiya TRF418
Old 07-11-2014, 04:44 PM
  #1366
Originally Posted by GMartinez
samix chasis will arrive next week www.superiorhobbies.com
I installed one on my 418 will test at the next club race
Will test the samix conversion this weekend too. I say it has a considerable change in flex characteristics.
Haven't heard from Kentech about the results from the race using this conversion?
inpuressa is offline
Old 07-11-2014, 04:46 PM
  #1367
GMartinez's Avatar
Trader Rating: 91 (100%+)
+1 also props to the quality
GMartinez is offline
Old 07-11-2014, 07:42 PM
  #1368
JimmyMac's Avatar
I wonder how this chassis (Samix) compares to the Smokem chassis.
JimmyMac is offline
Old 07-11-2014, 07:43 PM
  #1369
jdawg81's Avatar
I will be racing this car on carpet in either touring 17.5 blinky or vta. The samix conversion supposedly has more flex than the kit chassis so would this help improve performance of the car? Or is it mainly for helping to improve performance on outdoor asphalt tracks?
jdawg81 is offline
Old 07-11-2014, 09:01 PM
  #1370
Trader Rating: 47 (100%+)
+1 how will chassis do on the rug or is it jus for tarmac?
transplantlife is offline
Old 07-11-2014, 11:07 PM
  #1371
niznai's Avatar
You need more chassis flex for mod in low grip, not for 17.5.
niznai is offline
Old 07-12-2014, 01:14 AM
  #1372
My understanding of chassis flex is to have the right balance of flex vs suspension movement. If the chassis stops flexing before the suspension compresses to its maximum travel on a turn, you end up with a darty car. If the chassis keeps flexing too much, you have a lazy car. When you have the right stiffness, the car just becomes so much easier to drive imo.
I'm sure the softer samix chassis for the 418 will benefit all types of asphalt conditions in different classes. The stocker is simply too stiff. For carpet, I would try out the front steering brace included in the samix conversion. As far as the build goes, the chassis holes are perfect and everything went together fine.
Old 07-12-2014, 02:37 AM
  #1373
2-Bad's Avatar
Trader Rating: 24 (100%+)
Let us know how it goes.
I've tried 3 (in total) chassis's and after bolting on the Samix in early May I have no reason to take it off. The car works a lot better now in low and extremely low grip. Very happy!!
2-Bad is offline
Old 07-12-2014, 05:31 AM
  #1374
d16dcoe45's Avatar
which chassis have you tried? Are you running mod or stock?
The Samix looks tempting! Any comparisons with Samix and Raceberry Hard chassis for stock 17.5?
d16dcoe45 is offline
Old 07-12-2014, 06:18 AM
  #1375
2-Bad's Avatar
I tried the Kit chassis, a Berserk 2.0mm chassis, and the Samix 2.3mm chassis. I also have had made a Bersek 1.60mm, 2.00mm, and 2.25mm Top Decks.
I've only raced mod. Hobbywing 3.1V esc and Hobbywing V10 4.5t motor.
I couldn't comment if the Samix chassis will be better in the Spec classes. We need someone to try and report back.
In respects to flex its hard to define, but if the Kit Tamiya chassis was rated at a flex of 10 (hard), and the Bersek 2.0mm was a flex of 5, then I'm guessing then Samix 2.3mm chassis is a flex of 7.5
As said before, the faster you go the more chassis flex is required. the slower the car the more rigid the chassis needs to be. Of course there are exceptions, conditions, and circumstances that are contrary to this, but I've been very happy with the Samix thus far. Another factor to be considered is the Samic Motor Mount. This mount used 4 mount screws and are considerably narrower/more central on the chassis.
The Kit chassis I wrenched and wrenched on that thing. I could get it to steer and to have rear grip but could not give it cornerspeed. The Bersek 2.0mm was way better but stalled mid corner (too much flex). Samix seems to be the winner out of the ones I have tried (not saying there isn't another out there that could work just as well or better).
Heck, it seems even Kiyo has found a decent chassis for the TRF boys now (thanks goodness!!!, lol)
2-Bad is offline
Old 07-12-2014, 04:55 PM
  #1376
TB03Racer09's Avatar
Can anyone have a good guess when the next TRF will come? Just after worlds? December (exactly 1 year after last trf)?
TB03Racer09 is offline
Old 07-12-2014, 05:43 PM
  #1377
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Does Tamiya make any open ended ball connectors or do you guys go with another brand?
Or are most just drilling a hole or shaving the top part with an X-acto?
Dan is offline
Old 07-12-2014, 06:52 PM
  #1378
JimmyMac's Avatar
Cut the tops off with knife.
JimmyMac is offline
Old 07-12-2014, 08:14 PM
  #1379
also can use body reamer from top and bottom. mine came out pretty nice.
Old 07-12-2014, 08:53 PM
  #1380
JimmyMac's Avatar
The reamer is a good idea. I usually cut the tops off, then finish it with a reamer for a neater looking hole and to remove any burrs.
JimmyMac is offline
