TRF101
#917
Suspended
Hi Guys, Been a while since I posted, But I have decided to get rid of my TRF101 and go down the touring car route instead.
If anybody wants a TRF101 chassis, give me a shout. It's never been run, But has been built. Comes with an unpainted Mclaren BodyShell and wings, F2012 Wings set, a couple of sets of wheels, and loads of spare screws etc.
Cheers!
Cheers!
#918
#919
Who said the TRF101 isn't a great F1 car. It won the TCS race @ Middle River Hobbies on 1/19/2014. Had fast lap and won by 2 laps. Ok OK, Mike Gee probably could have done the same with any other Tamiya F1 car.
http://www.rctech.net/forum/attachme...2014_00001.jpg
#920
The last 4 races i drove my TRF101 to a victory
Each race i set the fastest laptime and last sunday i was 0.25 seconds faster (on a large indoor track) then the second guy who was also running a TRF.
I drove my car with just a silvercan motor while the rest of the guys had a hobbywing brushless 21.5T motor.
Very pleased with my TRF
#921
#922
#923
Front:
Gold spring, no pre load
Less camber option
4 mm ride height, no droop
20k oil on kingpins
Center shock:
Flourescent red spring
Kit oil
4 mm center ride height, 2mm droop over ride height
Silver side springs, no pre load
Links in outer position
20k oil in damper tube
4 mm ride height on pod
TCS tires. Fronts were glued up to the ridge on the sidewall. Full sauce rear, 3/4 front
Diff was fairly tight
You need to shim the front upper arm up 2mm in order to get 4 mm front ride height with no spring preload
#925
Anyone interested in a brand new unbuilt TRF101 kit, please check, I have 1 kit for sale:
http://www.rctech.net/forum/r-c-item...rf101-nib.html
#926
This was on carpet, medium grip
Front:
Less camber option
20k oil on kingpins
Center shock:
Kit oil
Front:
Less camber option
20k oil on kingpins
Center shock:
Kit oil
#929
Thanks!
#930
Sorry just saw this Carl. Pretty sure the axles were through the kingpin. 92/33 on the reedy motor, 38* timing. It was a standard battery, although I think shorty may have been better so the electronics would be more inline to keep the car more stable, but I wasnt about to buy a shorty pack for a rent a ride to try
