Yokomo MR4TC-BD
Old 08-01-2008, 08:26 AM
  #8326
Francis M.'s Avatar
Originally Posted by articnova
Hi Francis I dont think Martin can post since hes racing but if youre refering to this
http://events.redrc.net/wp-content/g...erYokomo-1.jpg
No its Chris Grainger's car but hes unwell and has withdrawn from the euros
Thank you, This seems to be the best layout of all the different configurations i've seen...........
Francis M. is offline
Old 08-04-2008, 02:07 PM
  #8327
Martin Hofer's Avatar
the main change is definatly not the chassi / topdeck or steering ^^
Martin Hofer is offline
Old 08-04-2008, 02:56 PM
  #8328
Francis M.'s Avatar
Are you talking about Grainger's car or yours? How was your car in the Euro Championship?
Old 08-04-2008, 11:14 PM
  #8329
we used the same car
he used a different topdeck than i did other than that there was no real difference
Old 08-06-2008, 06:10 AM
  #8330
updated my blog
http://binahof.spaces.live.com
Old 08-06-2008, 06:23 AM
  #8331
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Martin Hofer
Great report
Yokomo_Ant3 is offline
Old 08-06-2008, 05:01 PM
  #8332
Default Fitting LiPo Batteries in BD
I have recently purchased two sets of Orion 3800 Lipo batteries and have noticed they won't fit in the BD, as the top deck is in the way of the connectors. I have looked back through this thread to see if anyone else has encountered similar problems, and noted that some people are using the Stick Pack Battery Holder (BD118PH). It has also been mentioned that Yokomo have brought out a specially designed LiPo tray, although I cannot find any part number or picture of this! It would be greatly appreciated if someone could clarify what part is needed to make the LiPo fit and the item no. if possible?
Many thanks
rosey1990 is offline
Old 08-06-2008, 07:47 PM
  #8333
Dear Martin,
What exactly is the BD-3? A updated version of BDM or brand new BD? Will it realease to the market?
Notice a new upper deck, front & rear arms looked different, one piece steering bell crank.
MARKANO is offline
Old 08-06-2008, 08:02 PM
  #8334
Francis M.'s Avatar
Many thanks
I use a orion 3600 and had to grind down the bullet connector to clear the upperdeck. I'm not sure how much higher the 3800 is vs the 3600...
The stick pack holder secures lipos such as trackpower or checkpoint since those packs does not have the bumps on the bottom of the case and can be moved out a bit....
You can grind off the bottom of the lipo case so you can move the pack out by a few mm if you really need a quick fix...
Old 08-06-2008, 08:13 PM
  #8335
caltek1's Avatar
Trader Rating: 38 (100%+)
rosey1990,
I have been using the 3800 Ip Lipo with the Stick Pack Battery Holder (BD118PH). I removed the plastic battey holders. I also added a spacer about 1.5mm on top of the graphite holder, so that I could still use the graphite battery strap. This worked a treat. I also don not run the chassis stiffener post which allows the battery to sit in closer.
I will see if I have any pictures. The other method if you want to use trackpower 4900, etc is to get one of the bitty Lipo holders. I will post a picture when I receive mine.
BTW
With both of these holders you do not have to cut any part of the car.
Later
Calvin.
caltek1 is offline
Old 08-07-2008, 04:24 AM
  #8336
Default Thanks
Thanks for your help guys, much appreciated! Don't particularly like the idea of grinding the bumps off the lipo pack in order for it to fit the stick pack holder tray, so I had another look at the LiPo in the car this morning! Took the plastic battery holder tray out and put the LiPo in as far to the edge of the chassis as possible (in the battery slots) and it appears as though I will just about be have enough room to put the bullet connector in without it hitting the top deck. If not, i'll just grind some of the connector! Although, not sure on how secure the battery is likely to be in an impact without the std tray! Caltek1, it would be great if you could post a picture of the LiPo tray when you get it. Don't suppose you have the part no. for this item so I can look into getting one?
Old 08-07-2008, 05:27 AM
  #8337
Rob Burns's Avatar
I've used the Orion 3200 in the BD. I didn't remove the bumps from the battery but I did remove the battery trays from the car. I found that I wired one of the terminals at a 90 degree angle and I would installe the wire into the battery then install the battery into the car. Never had an issue with it shorting out on the chassi or the battery moving. I did tape the battery in aswell as use the strap as an added precaution because the strap doesn't hold the battery totally secure and tape alone can rip.
Rob Burns is offline
Old 08-07-2008, 06:00 AM
  #8338
caltek1's Avatar
Default Bitty design Lipo trays
rosey1990,
Find link to article on redrc.net that has these lipo trays. I know that the tray with the offset fits the BD. I am waiting for one to put in my car. It does overhang the chassis a little, but does not interfere with anything.
http://www.redrc.net/2008/05/bittyde...-battery-tray/
Regards,
Calvin.
caltek1 is offline
Old 08-11-2008, 11:00 AM
  #8339
m3ndo5a's Avatar
I wanted to share a ackerman/steering mod I done to my BDM, I did this mod to my 416 and EVO5MS and the steering is WOW. I've seen some guys go with the HPI castors, but I decide to go Xray2008. The corner speed and infield steering that the ray08 pretty much out performs most.....but I have open pandoras box. The BDM steering needed just alittle more inside wheel out throw for me to stay on the sweepers full throttle without pushing out...... and sneaky turn ins on the 180*.........YEAH BABY
This upgrade is about $40 bucks but it worth every penny.
First and Second Xray008 parts on the 06 BDM.
The thrid picture shows the huge gain in steering throw.
The forth picture shows the wheel closer towards the lower shock position middle.
note: your inside rim will sit close to the arm, 15* may need to be shave off depending on the rims your are running.
You will need 1/8 bit to shave the hole out for the Xray Front or Rear(P) hinge pin.
008 Castor 4* or 6* med
008 Steering
008 rear Hing Pins
008 steering Bushing $13
I've modded the CVD's Corally Steel bone and pins with Rayspeed axle.
You will have to use Yokomo Ball bearings in the Steering block, Yes your wheel block will sit back about .5 mm
aluminum Spool
Xray springs 2.8f and 2.6r
Attached Thumbnails Yokomo MR4TC-BD-dx3r-101.jpg   Yokomo MR4TC-BD-dx3r-102.jpg   Yokomo MR4TC-BD-dx3r-103.jpg   Yokomo MR4TC-BD-dx3r-104.jpg
m3ndo5a is offline
Old 08-11-2008, 01:39 PM
  #8340
Hebiki's Avatar
Trader Rating: 26 (100%+)
Francis, i sent you a PM. thanks dude.
Hebiki is offline
