Hot Bodies Cyclone
Will any of these pistons work as an alternate to the 3 hole 1.1'a?
Are there any other options?
-Korey
Guys... can anybody confirm that uneven rear toe is caused by the rear hubs? I replace the rear hubs with my pro4 spare rear hubs and I supposed they are not molded right also... I have yet to try other brand rear hubs. Have anybody get around this problem other than buying the aluminum rear hubs or changing to tamiya 416 rear hubs and pins?
There is a fix some of the team are using in here Europe...
First measure the toe of each rear wheel and then use a 2.5mm drill bit to correct the angle of the hingepin hole.
It'll make the hingepin hole a bit too big and give slop side-to-side, so drill two holes in the rear of the hub and put in grub screws, using the original grub screw and the two new ones its possible to tweak the hub to the correct toe using a setup station.
You can use Tamiya 3 hole pistons if you are in a bind. They are also a 1.1mm 3 hole piston, and they fit great. You might have to add a thin shim or something to reduce the slop between the e-clips and pistons. I noticed if you use the ti nitride shock shafts HB has, they fit perfect on the tamiya pistons.
-Korey
-Korey
Would you happen to have the Tamiya pt#.
Thanks.
I have just been looking at the pics form the Euro's, looks like Volker is running a few different settings, top deck has been split all the way down the centre, with the rear deck seperated. and it also looks like he is running different front driveshafts, look remarkably similar to losi double joints.
Check out the pic on redrc.net coverage
http://events.redrc.net/event-galler...ros/?nggpage=5
Anyone think thats a 3.5 rear toe block on the car?
Any ideas as to what brand it is? Development part?
Actually i just noticed the front block is the std block, so he was running 3.5 toe.
Man that track must have been very slippery.
Ahh thanks besercoe, ive never seen one of those before. for 19T up i usually always see 3 degrees on the rear and have wondered whether you would loose much speed with more rear toe.
I tried running 3.5 once and it was not too bad, i went to 4.0 and it was a weapon for the first half of the race, but after that it overheated the rear tires and it was a big effort to drive it
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Yes it is caused by mis-molding of the rear hubs, it is a pretty recent isse, your old Pro 4 parts should give equal toe.
First measure the toe of each rear wheel and then use a 2.5mm drill bit to correct the hingepin hole.
It'll make the hingepin hole a bit too big and give slop, so drill two holes in the rear of the hub and put in grub screws, using the original grub screw and the two new ones its possible to tweak the hub to the correct toe using a setup station.
STLNST... I have yet to run the car I'm still using my old and trusted pro4 here in parking lot racing.. so still have to see if the uneven toe will result in uneven tire wear. Did the uneven toe affect the handling of the car.. say if the other is 3degrees and the other is 2degrees...
Has anybody tried the HPI rear hub 31417 1/R/L with 2* rear pivot block ???
That would still give you 3* rear toe. There is supposed to be some advantage to having 1* at the wheel and 2* at the pivot block but I don't know what that advantage would be for sure ??? I would like to know more about this combination before I try it myself.
Hey Russ, this is something I found on one of the car sites :
Inboard toe-in will give your car more support in the rear. This will give you a car that drives flatter over the rear and will transfer more weight to the front of the car during off-power transition. With outboard toe-in, you will have less support in the rear which will result in less overall rear traction. The car will also hold more of a set over the rear of the car and less initial steering in off-power transition.
