Old 05-13-2014, 03:54 PM   #1036
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Ph3nyx View Post
i've the 574 in stock but the car il already touchy with the 571, Unfortunatly i don't have the 575
5° of caster and 1°toe out
i've tried different setup around the central and the laterals dampers but nothing that realy improve the car.
You can try less caster, gives you better stability on corner exit but good steering on corner entry.
575 Rears (softer) like Wheelz says and JackGripper or SXT3.0, which is more consistent over 15 minutes to keep the tires from collecting carpet grease and fibers.
What front springs are you using?
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-15-2014, 06:28 PM   #1037
Ph3nyx's Avatar
i use the tamiya black (medium)
i'll try less caster tomorrow and maybe a stiffer diff
you'll be informed of the result thx Mike
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 05-20-2014, 04:15 PM   #1038
Ph3nyx's Avatar
Back from the track with less caster and a complete clean diff ! it's better but the issue is not completly resolved
the car as the potential , but it's not easy to get it with those tires !
Old 05-20-2014, 09:20 PM   #1039
MikeR's Avatar
Yes, tires are 75% of the handling especially when its 2wd
Old 05-21-2014, 12:08 PM   #1040
cmunro's Avatar
for anybody looking for a complete f1r2 ,i have one for sale in the classifieds it has been the best chassis i ever had just makeing the move to 1/12 scale
cmunro is offline   Reply With Quote
Old 05-21-2014, 05:56 PM   #1041
Ph3nyx's Avatar
in my configuration i've put the battery backward and the esc in front, do you think it could be better with the battery in the front (transfering mass to the rear on accel ) ?
Someone have tried both setup ?
Old 05-22-2014, 05:11 AM   #1042
Thought I would share how I was able to use the additional M3 holes at the front of the chassis on my F1R2. I've also widened the car 10mm at the front and back. Less and less Tamiya is left over. Just the rear axle and differential now.
J-PaP is offline   Reply With Quote
Old 05-23-2014, 09:47 AM   #1043
Ph3nyx's Avatar
very nice ! 190mm wide ? How did you manage to widen the rear ? shims on the axle ?
Old 05-23-2014, 09:56 AM   #1044
wheelz's Avatar
Wow those are really nice!!!! I'm sure more and more people will be converting their front ends over when the 101W comes out. How long did that take to make?
Aaron Lane
Team Associated | Exotek | AKA | LRP | Airtronics l OCRC l Sticky Kicks l
B5m | B44.3 | Exotek F1R3 l TC7
wheelz is offline   Reply With Quote
Old 05-23-2014, 11:13 AM   #1045
Rear is widened using the Rsector widening kit plus 2mm shims on the axle.
Hard to put a time on it. Manufacturing itself is quick though the CAD drawing takes a bit of time mostly due to having someone draw it up using sketches/standard tamiya lower arm set and the components to make the whole lot attach to the existing chassis/kingpins.
As the top arms now mount in a different position there was a bit of working out lengths of turnbuckles and the arms to tune caster/camber/toe. As you can see I've resorted to using different ball ends to make them fit.
Old 06-01-2014, 03:52 AM   #1046
pug205's Avatar
Hi Guys,
I am looking to get the F1R2 and have never run a car with the side psrings before. Is it easy for the springs to fall out after a hit or roll and can the Tamiya side springs (part 54352) be used on this car? As I cannot find where to buy the Associated springs from.
Cheers
pug205 is offline   Reply With Quote
Old 06-01-2014, 08:00 PM   #1047
Ph3nyx's Avatar
Tamiya's springs will work fine
i've never lose a spring so far on a hit
Old 06-01-2014, 08:09 PM   #1048
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by pug205 View Post
Hi Guys,
Cheers
Brett - only ever had one go walkabout and that was because I hadn't put it on properly. However, tqrcracing carries a good range of Associated parts, including the side springs.
Phil.
T4 | X1 | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 06-01-2014, 08:16 PM   #1049
evochick's Avatar
and if you are really paranoid just put a little dab of shoe goo at the top of the spring, after you install them.
UnRetired
evochick is offline   Reply With Quote
Old 06-01-2014, 09:23 PM   #1050
pug205's Avatar
Thanks for the info guys, I appreciate it .
(Hope we get to see you back at the track soon Phil!)
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F104 Pro! NT Electric On-Road 9327 01-11-2017 01:04 PM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
SEO by vBSEO 3.5.0
