Team Much-More cell master v1
#1396
its a 3 cell i charge mine on the lipo mode on my cell master apperantly you can charge that pack on linear mode as well i havent tryed that yet .
#1397
i will discharge my 8pcs AA batteries into my Cell master and i dont know what voltage cutoff should be on AA batteries... do you think 0.9v per cell or 7.2v as a pack or it should be 0.1 or 0.8 as a whole pack...???
#1398
hey
my fans on my ctx-d2 en cell master make an extreme amount of noise, when im charging/discharging i can't really hear people talking (yeah its that bad)
what can i do about this ? different fans ?
thanks
thanks
#1399
u guys must be talking too softly j/k.
yes, the fan is really loud. .. MUCH louder (hence MUCH MORE ... ) than LRP comp or CDCs ..
that's why i can use it to charge batts in office for fear of sparking security alert
i suggest u compare your charger against a similar charger at your track to see if it's louder than usual.
#1400
Originally Posted by freekthefreak
hey
thanks
thanks
#1401
when im charging my stick packs i noticed that the voltage is going down?? why?? and when discharging the voltage goes up?? hehehehe is there something wrong??
#1402
you mean at the start of the charge process??
if that happens means your batts are on the way out. my guess is it starts off at above 9v then drops below 9volts before repeaking above 9volts.
your packs has higher Internal Resistance and wont hold its voltage very well at high loads (i.e at full throttle)
#1403
#1404
there dying. use as practice packs.
u prob let them sit for too long without charge or there just old
#1405
#1407
Team Much-More cell master v1 Wont charge flat Lipo or lithium ion cell
Hi all,
I have a problem to charge my li po using Team Much-More cell master v1 when its Flat it says error message "Battery Volt Low Check Connection". The connection is fine. I have check to look at the voltage of the battery using multimeter and it was 0.5 Volt. Is there any way that I could get my battery pack to charge using Team Much-More cell master v1.
#1408
Originally Posted by Tony Vega
What CTX profiles are people using with 4 cell IB4200's? What are people using for mAh cutoff?
#1409
Originally Posted by SuPeR
Hi all,
#1410
.5 volt is way to low they shouldnt go below 3v per cell
