Team Much-More cell master v1
#1249
Originally Posted by nikkiesteban
hello team much more.. what is the main differences between the ver1 and ver2???
#1250
They should be landing sometime this week or next to the dealers.
#1251
Hey Guys,
Just a few quick questions, I got one of these babies, I am in love with it!
Ok here are my Q's:
1) Is it better to CTX or linear charge IB4300's?
Is this the correct CTX charge settings for this battery:
CTX Step 1 - 7A to 3000mah
CTX Step 2 - 7A to 3050mah
CTX Step 3 - 7A to 5000mah - 03 cutoff, 50 degree cutoff
Repeak in Linear @ 7A with a 10 cutoff
2) What is the best profile setup for the GP4300's? I do know that I should deadshort them with my CTX-D2, what then?
3) I have read this thread on Long-lockout however still cannot get my head around what it is meant to do or help with.
4) Can somebody please explain to me how delta peak effects the battery when temperature is taken into consideration.
Sorry for all the Q's!
Naut
Ok here are my Q's:
Naut
#1252
Shop Owner
1. linear
2. linear again, and DONOT deadshort 4300 if you want the pack to last.
3. In order to avoid false peak and having your battery not fully charged. Basically, for the period you set charger doesn't check for voltage drops
4. The higher delta peak you have the more temperature your battery will end up. Ussulaly on hot days, I have 16 and on cold 24-30 (6 cells)
Nick
Nick
#1253
linear for sure.
As for delta peak, you need 130 degrees at peak for optimiun performance this should be around 20 or 30 you will need to play with it and see where you need it but 20 should be a good starting point.
#1254
Originally Posted by Nautilian
Hey Guys,
Ok here are my Q's:
Naut
Ok here are my Q's:
Naut
The whole reason for CTX (step) charging is to allow you to give your cells a break to cool down after hitting them with a higher amperage - using 7A for all three stages will kill your cells. Example would be Step 1: 7A - 3030, Step 2: 0.5A - 3050, step 3: 5A - to peak.
What is important though is the type of battery you are charging. In your post, you mention you have an IB4300 ... they don't exist. Either it's a GP4300 or an IB4200 - both which require different charging profiles. For GP's, you may want to try a step charge - but most that I have spoken with are getting great results with linear charging... for IB's, just charge at 6A linear.
#1255
Some people set the same charging rate in all three steps as a way of setting a lockout based on mAH instead of time (CTX charging is locked against delta peak cut in the first two stages). He probably took that profile out of context.
#1256
Sorry I meant IB4200's and GP4300's
I have not used that profile, I am just trying to find my bearings with this charger before I start using it. Hence why I am here asking the Q's.
So just to check:
IB4200's linear 6A with 20 delta peak (obviously the delta will change according to temp)
GP4300's - What should I be looking at for linear? As well as what should I be trying on a step charge?
Thanks in advance.
Naut
So just to check:
Thanks in advance.
Naut
#1257
Originally Posted by Anthony.L
Mainly the case, screen backlight, and limited edition status. MM is only making so many of each color, I've heard less then 400 coming to the US. There was also mention of a small software update, but the tech specs don't show any new features persay.
#1258
Nautilian, we recommend that you start with a lower delta peak, somewhere in the range of 06 to 10. If you find that your cells do not get up to temperature, then begin increasing the delta peak. You will often see people using higher delta peak settings in cooler weather.
Also, keep your temp cut around 48-49 deg C, as your batteries will be gaining heat even after charge.
#1259
Cell Masters
I currently have two Cell Master V1 and I am very pleased with them. Anyone know if there will be a upgrade kit to the new special black LCD screens?
#1260
Shop Owner
Originally Posted by BlueR1
wow these rc companies really know how to make money. 400 to the USA, how many sold to HK, Japan, Europe? not really that limited
Nick
