Team Losi JRXS
#1636
Regional Moderator
Speaking of balance...
All but one of the pics I've seen so far have been with the car running personal transponders, so where will the best place be for the regular transponder. I'm thinking the only real option is between the front body post. The one pic I saw had it in a lexan 'box' atop the upper deck.
Seems like that would be waaay too high for something that heavy.
Just a thought....to keep the thread off the third page again...
#1637
most people i know usually put the transponder in the fron window or under the wing at the back
#1638
I think most racers would want it more in front... if you're running a very close race..who would win... the car with the transponder in front or the car with the transponder in the rear...?
#1639
Regional Moderator
Originally posted by rc-zombies
in the back?
in the back?
Of course, we can always just depend on the racers to tell the truth... ...okay... Couldn't hold the laugh in...
#1641
Originally posted by Darkseid
I'm usually not a fan of having the transponder in the body, but that is an option.
#1642
what u could do is get a piece os lexan and put the lexan on top of the servo then have the lexan extend out to the right side of the car and have a hole and put the transponder through the hole then put your body clip through. Thats what i did with the XXX-S and had it come back behind the servo so its sitting low as possible.
#1643
.....kinda like most of the TC3/4 transponder mounts. There are aluminum servo mounts that hold the transponder. I'm sure they're surface for the JRXS once the aftermarket gets a hold of the car.
On another note, I wonder if the personal transponder will fit on the chassis in between the front swaybar ball-ends? Looks to be a bit tight, but that would be ideal placement.
Does anyone know how the car looks at the NOVAK race? I heard MF won a heat with it, after battling with Paul L's Pro-4. Any of you guys at that race right now?????
#1645
I allways mount the transponder in the foam bumper, when i oval raced. It just seem smart to me becuase that is the best place for it, plus i looked at everyones car that i was in comp with, they would have it mid to rear on the car. I allways thought that was not a smart place to put it. But some use the Transponder as ballast. So i can see why they would mount it where they did. But I think the front is the best place.
#1646
No Oneway
What a bugga, no one diff for the front of the JRX-S, for that I have just removed this car from my shopping list.
Buy a pesonal transponder and stick onto the bumper
#1648
NICE
#1650
Originally posted by Gearhead3
NICE
NICE
We sure did miss him at the NorCal Carpet Championships in Stockton today.
