Ask Steve "The Evicerator" Weiss >
Old 02-05-2009, 08:03 AM
  #6721
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Syber Serulean
steve, will a spread spectrum GTB work with my mx3 FM radio?
I just wanted to share that I have been using an SS GTB with a 75mhz FM radio and as long as the receiver is an inch or so away from the ESC I have no problems whatsoever. I just put my receiver on top of the servo to give them some distance. If I put the receiver on the chassis next to the ESC it glitches like mad.
M-Technic is offline
Old 02-06-2009, 04:37 PM
  #6722
Scott B's Avatar
Trader Rating: 47 (100%+)
Hey Steve I found some pics of some new Novak motors, "Ballistic's". Any info on these??
Scott B is online now
Old 02-06-2009, 04:46 PM
  #6723
The Evicerator
Hey Scott,
Hadn't seen any pictures surface yet myself!
The Ballistics are our new line of modified motors. We will first be introducing them in the 3.5 - 8.5 winds.
These motors will feature a redesigned rear end bell assembly that allows for easier timing adjustment than before and it also offers users the convenience of replaceable sensor harnesses... all in an innovative new package.
We are going to hold off on releasing other winds based on the ballistic due to the fact that many series around the country use our motors exclusively and we do not want to "force" people into feeling like they need to buy a new motor right away in order to continue competing in the series that they are currently running.
Steve Weiss is offline
Old 02-06-2009, 04:50 PM
  #6724
Diego Racing's Avatar
Steve Weiss.....You are my hero, Thanks for your help at the birds, I will keep in touch.
Diego Racing is offline
Old 02-06-2009, 04:52 PM
  #6725
FERNANDO.G's Avatar
FERNANDO.G is offline
Old 02-07-2009, 10:28 AM
  #6726
The Evicerator
Wow,
Being hero to both Fernando and his son Diego is definately the highlight of my day thus far!
Old 02-07-2009, 10:45 AM
  #6727
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Ghai.....
L.Fairtrace is offline
Old 02-07-2009, 02:35 PM
  #6728
tmunno's Avatar
Steve thanks for all the help and assistance at the Snowbirds. Tony/Lynn Munno cya next year !!!
tmunno is offline
Old 02-07-2009, 08:34 PM
  #6729
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Hey Scuba
Had any STEAK lately? You animal......
Thanks for checking out that 17.5 for me it was FAST in the main.
Ron Goetter is offline
Old 02-07-2009, 08:36 PM
  #6730
schreff's Avatar
Originally Posted by Ron Goetter
Hey Scuba
Scooba loves a side of beef with his rotor lubricants.
schreff is offline
Old 02-08-2009, 12:27 PM
  #6731
The Evicerator
Ug....don't remind me about those "rotor lubricants!"
How you guys doing?
In fact I had some steak last night...but I had eating utensils...so there was no "Skuba Vs. Wild" re-enactment.
Ghai!
Old 02-09-2009, 09:00 PM
  #6732
This might be a dumb question but can the Spread Spectrum GTB 4-Cell be used with any 2.4 radio? ie my Futaba radio? I just want to make sure before I get one online. Thanks
Ophidian is offline
Old 02-10-2009, 07:47 AM
  #6733
The Evicerator
Yes, the spread spectrum GTB is intended for use with any 2.4 GHz system.
Old 02-10-2009, 08:18 AM
  #6734
chris moore's Avatar
Trader Rating: 96 (99%+)
Steve, I want to try a 13mm rotor in my touring car, will the smaller air gap make the motor run any hotter? And will I need to change the gearing any with the different rotor?
Chris
chris moore is offline
Old 02-10-2009, 08:29 AM
  #6735
The Evicerator
Hi Chris,
What motor are you planning on running the 13 mm rotor in?
Usually when going from the 12.3 to the 13 mm rotor I gear up two or 3 teeth with a 3.5 or 4.5 turn motor.
Once you make the gearing change everything should run about on par with where it was before, but with more torque/consistant braking.
Hope this helps!
