Team Associated TC4
Do people run the Factory Team TC4 without th Top Deck Standoff? Maybe for pavement of more flex? I purchased one used and it is missing the Top Deck Standoffs.
Thanks,
Thanks,
R/C Tech Elite Member
Will the B44 out drives fit the TC4?
I have a TC4 I want to run in a VTA class, one of the rear outdrives is trashed and unusable, will these work as a replacement?
I still have a FTTC4 and if you setup the car with the 4 corner braces and the spine, the car/chassis will be very stiff with very little flex. This car was designed when foam tire carpet racing was popular, so a chassis will little to no flex was desirable. There were also different thickness of lower and upper decks that could be used for tuning the car.
I did a quick search on Team Associated website for the FTTC4 and it has some useful links. Here is the result of the search... (https://www.associatedelectrics.com/search/?q=fttc4)
Here is a direct link to the FTTC4 manual... (https://img2.associatedelectrics.com...4ft_manual.pdf)
The last time I seriously raced my FTTC4 was on low grip gray ozite car in VTA using Protoform VTA tires. I removed all 4 chassis braces as I felt the car was too stiff for the track conditions I was racing on.
I remember some people (setups) where they were modifying the upper deck for more flex. If I were going to revive my FTTC4 for racing, I might look into getting the top deck that came with the Diggity Designs DC4. That car is a more modern aftermarket upgrade for the TC4 that was competitive when racing rubber tire classes such at 17.5 TC. That car used the same motor mount as the FTTC4, which is the part that is almost impossible to find new at this point.
Here is a link on the Diggity Designs website for this car, but I do not know if this company is still in business or producing any new parts. I do know they had a limited run on the conversion kit that ended long ago... (http://www.diggitydesigns.com/produc...signs_DC4.html)
Hope this information helps
I cannot tell from the pictures nor have I tried to use the B44 parts. I would suspect that the B44 outdrives would be too wide and the dog bones would bind if used on a TC4, but I just don't know. However If I was going to take the risk, I would buy the complete diff assembly which is Team Associated part number 9735. I found a couple of them for sale on Amazon.
You might try search online for B44 vs TC4 diff assembly. I found a few discussions but didn't see anything that confirmed they were interchangeable
