Ko Propo VFS-1 ESC
#827
hello ko staff
can u tell me:
1.what is the default neutral brake setting for professional version of vfs1?
2. is the original setting ok for 4 cell, 8/9t 1/12 running on medium traction track?
3. can i use a 5 cell 6v receiver pack in case 2 above?
cheers
cheers
#828
Originally posted by 403forbidden
Where is the cheapest place to buy the PC Adapter? $75 seems to be a bit much for a serial connector and simple software...
Though $75 does seem a little painful on the wallet
#829
re the hara twister2 where can i find the default profile settings for this speedo??
Gr8 speedo like it loads
#831
Re: hello ko staff
Originally posted by RC12L3a
can u tell me:
cheers
can u tell me:
cheers
Try Hara's or Masami's setting on the website for 1/12. This was used for them at last year's Japan nationals.
When using a receiver pack, the red pin on the lead must be disconnected going from the esc to the receiver. DO NOT CUT the wire. You will need to re-connect it when programming.
#832
I know I was reading this before but canīt find the information again. What is the drive frequency with the factory setting?
Regarding programming, is it possible doing all the settings with the handheld adapter or do you need the PC adapter for this?
#833
yes. you can do everything with the handheld programmer. PC adapter will allow you to see the throttle profile visually.
#834
hey whats the lowest drive frequency on the speedo?
#835
Originally posted by Hebiki
stage 36 across the entire profile is the factory setting.
stage 36 means 3.98 kHz right?
Are there any more new informations on the new KO ESC? I was reading something of a higher spec version than the current VFS-1. I thought this is the VFS-2 but now I found on the KO site this is a budget version.
#837
Thanks. Superfast answer.
the new Ko VFS has a carbon graphite looking case. the thermal shutoff feature has been removed. its called VFS-1 Competition
thats all i know. ill find out more this week.
VFS-2 replaces the KSC-1200 series escs.
#840
Registered User
I run a ERG-VRX with my VFS-1 and it works fine, have done for about 6 months and have never had a problem.
Ben
Ben
