Ko Propo VFS-1 ESC
#1741
Originally Posted by nah604
thanks, I must of given up at about page 20.
So will this profile work for 19t as well or my motor is going to start smoking.
yes you can use it in 19T, your motor will require more maintenance (cutting, brush wear, etc). i suggest you drop the entire profile 5-7 stages if you are just practicing. on race day... then crank it up
#1742
Originally Posted by Hebiki
a profile in 27T and 19T won't cause your motor to smoke. improperly gearing it will (i know.. ive done it. MANY... MANY... times.. )
In a 1-12 scale running stock how much will the frequency really change comm and brush wear? The reason I ask is because I just started playing with my VFS-1 and PC Interface and was wondering what to expect if I use low frequency settings.
#1744
Originally Posted by ROBORAT
hi guys. i just got myself a masami edition, VFS1 Pro. Just wanted to ask if the stock settings on this version is more aggressive compared to the hara twister edition. thanks in advance!
#1745
Yes, a mod setting from Atsushi Hara.
#1747
nah604: yes, actualy both the hara twister and masami versions come with mod settings (which is waht i run), but i'd like to know which of the two come with more aggressive mod settings. thanks again.
#1748
#1750
Originally Posted by Runin Ronin
This part is $40 at my local Radio Shack! Is there another and cheaper option???
ebay.. $10.00 or less shipped
http://cgi.ebay.com/USB-to-Serial-Ca...QQcmdZViewItem
#1753
i has anyone got on here a link to or could put the file on, of the spreadsheet that shows what all the settings numbers mean in actual khz settings i know i have seen it somewhere before just cant rememebr where , have looked on the ko website but to no avail
#1754
#1755
Thanks Ramon! I'm gonna swing by Fry's after work just to see if they have one near that price otherwise, eBay it is. Thanks again.
