Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 01-28-2006, 04:01 AM
  #1726
tcmerf,
Hey, from personal experience with the hara 2.1, i would say, do it. Everyone can benefit from a little more kick exiting corners and starting up. Its mastering how and when to use it that should be the main concern. Give yourself the option of extra punch by adding capacitors. I use 2x 4700 uf caps to give me what I want...
my $0.02
patrick
rcnewb2004 is offline
Old 01-28-2006, 07:45 AM
  #1727
beerbarron's Avatar
Hey guys I got the PC interface to porgram my KO stuff and I am having zero luck. My laptop does not have a9-pin male conector on it, so I purchased some adapters to convert a 25-pin LPT port. So far its not working. Has anyone got any experience they want to share? Or am I just not going to get this to work without a 9-pin COM 1 port?
beerbarron is offline
Old 01-28-2006, 08:17 AM
  #1728
Scrad's Avatar
Trader Rating: 16 (100%+)
Put the capacitor on. I've used a KO digital servo while running mod and when I'd punch it from a full stop the servo would pull to the side b/c so much power was being drawn to the motor.
Scrad is offline
Old 01-28-2006, 11:47 AM
  #1729
subman's Avatar
Same here any help would be great!
subman is offline
Old 01-28-2006, 01:44 PM
  #1730
Glowster21's Avatar
Trader Rating: 136 (100%+)
Have you tried to convert it from a DB9 to a USB? That should work fine.
Glowster21 is offline
Old 01-28-2006, 02:33 PM
  #1731
beerbarron's Avatar
Nope, will that work? I assume they make a DB9 to USB adapter. Also, how do you make a USB port into COM 1 or 2? Is that needed? I wish this stuff was USB. Plug and play is so much easier.
KO guy?
Old 01-28-2006, 03:22 PM
  #1732
You can get USB - 9 pin serial convertors. I know a couple of people that use this method to connect the VFS to their laptops. You can set in the COMM port in the software, anywhere from COMM 1 - COMM 10.
MattW is offline
Old 01-28-2006, 05:42 PM
  #1733
CRASH's Avatar
Trader Rating: 26 (100%+)
Default USB to Parallel Port
Yes it is real easy to do. Just get the Radio Shack converter, Part Number is: 26-183
Just install and it should set itself to an active port. Then you can select wich port to use in the KO software. If not go into My Computer, right click, select properties and the hardware tab. Devices tab, find the Radio Shack usb tab and open it and change the port setting to the one you want.
Hope this helps,
CRASH is offline
Old 01-28-2006, 06:28 PM
  #1734
Glowster21's Avatar
Robert,
Got my speedo back on Friday. You 'Da Man!!!! Thanks for the awesome service. SOOOOOOO glad to get that stinkin' LRP junk out of my car and go back with a real ESC.
Thanks Again!
Joe
Old 01-28-2006, 06:57 PM
  #1735
beerbarron's Avatar
Crash and Matt- Thanks for the help. I'll return the adapters I have and go the USB route. I am really looking forward to my own profiles on the VFS.
Edited- I got a USB adapter (Belkin) and it works great. Just Install the software, set COM port to 1 and that's it. The KO software now communicates.
Old 01-30-2006, 12:48 AM
  #1736
Default KO Twister and Lipoly.
Does anyone know if you can set the speedo to cut out at 6v ?
blocky is offline
Old 01-30-2006, 02:38 AM
  #1737
Hebiki's Avatar
the highest the handheld programmer goes for the cutoff is 4.0V
Hebiki is offline
Old 01-30-2006, 10:45 AM
  #1738
Does anyone have a good stock & 19t profile they would like to share? I've search and can't find what I need and it's 40something pages.
Carpet, medium size, somewhat technical. at most 50% off throttle, rubber for stock, foams 19t.
Thanks in advance.
nah604 is offline
Old 01-30-2006, 12:15 PM
  #1739
Hebiki's Avatar
Thanks in advance.
here you go! it was on page 23, post #662.
Originally Posted by Hebiki
RBLove is right. call him up for help
for stock... try this setting...
5 <--- starting point for throttle curve
5
4
4
4
4
4
4
3
3
3
3
3
3
2
1 <--- throttle half way pressed (stage #16)
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17 <--- throttle fully pressed. white knuckle and all
enjoy!
Hebiki is offline
Old 01-30-2006, 02:01 PM
  #1740
thanks, I must of given up at about page 20.
So will this profile work for 19t as well or my motor is going to start smoking.
nah604 is offline
