Team Corally RDX Touring Car
#6228
Someone help me out here as I am drawing a blank. On the Corally setup sheets for the RDX, what are"Shims under couplers?"
Thanks in advance!
Thanks in advance!
#6229
Thanks in advance!
Thanks in advance!
Hope that helps clarify it.
-Shookie <><
#6231
Originally Posted by senna555
I spoke to you earlier in the week about the new left side motor mount and I understand they are out of stock.
If I order one online will it be backordered and shipped when it arrives or will you post when they are in stock.
Jamie
Jamie
Jeff
#6232
I revived some threads in the Corally Products forum. I also opened up some new ones. As you will see from some of the dates on the threads we had been posting new items in there as we did not want to flood the Electric Onroad area. Feel free to post direct questions in the forum below. Thanks guys.
http://www.rctech.net/forum/forumdisplay.php?f=67
Jeff
Jeff
#6234
Originally Posted by HarshGuy
Who ....me?
Man, you dremeled that thing fast. How did that work out?
Jeff
#6235
Originally Posted by Jeff Brown
Now you just have to work on your wire skills to clean up the chassis look.
Jeff
Jeff
And the "Multi purpose cutting kit" to limit the depth it cut at:
Set it to the same depth as the sink for the motor mount and dremeled the part that the motor mount stretches out on, then set it for the depth of the motor clearance and extended that, and viola!
#6236
NICE!! Now offer a service for it. haha.
Jeff
Jeff
#6237
Jeff
Jeff
#6239
hehe ...well one thing I should have done was wore a long sleve shirt and a mask, didn't think about the graphite shavings flying everywhere with that dremel going full speed, last night I felt like I had crawled through an attic full of fiberglass insullation!! ...I'm pretty sure I took about 5 years off my life, but in exchange for that I got the new bulkhead/motor mount, so it's worth it
#6240
In regards to using the Tamiya 3 hole pistons in the shocks, I'm curious how *big* of a difference it makes, or more to the point *what* difference it makes ...same thing with the extra long rear shock extensions, I tried the non-viagra version of the extensions and they really made a difference, I loved the way they felt compared to no extensions ..at this point any changes I make I can't test till round 1 of practice at the nats .
Also does anyone have some pics of the extra long chingaderas and how they mounted the shocks to them? Using a ball stud and ball cup on mine rubs the rear tires, so I must not be doing something right? Or using the wrong studs, or something!!
