Team Associated TC6 Thread >
Like Tree20Likes
Old 03-22-2012, 05:29 PM
  #6301
d2dap636's Avatar
Originally Posted by BlackStarRacing
I'm going to be real I really don't feel like spending 20 for some brand name tape.... Any one using anything else our no where to get some inexpensive solution?
I use a velcro strap from TOP racing, you can find it on amain. It works great and looks even better.
d2dap636 is offline
Old 03-22-2012, 05:31 PM
  #6302
Originally Posted by grippgoat
Oh, is that why I tap the boards so much with my TC6.1?
-Mike
And to think I was the only one!!!
uatemycookie is offline
Old 03-22-2012, 05:41 PM
  #6303
Maybell's Avatar
Originally Posted by justchris
Hi all
When building the AE gear diff has anyone had problems
with the small o-ring.
( i split one)
Thanks in advance
Its a pretty thin o-ring. Make sure to put some oil on it before you slide in on the outdrive. If you dont, the o-ring could be "grabby" as you install and it could rip. The diff is awesome and doesnt leak!
Maybell is offline
Old 03-22-2012, 06:12 PM
  #6304
Thumbs up
+1, works great!
http://www.amainhobbies.com/product_...nt-Strap-Black
ChampRC is offline
Old 03-22-2012, 06:17 PM
  #6305
Timbulb's Avatar
I bought the Hudy tape ($25 a roll) two years ago and still have 3/4 of the roll left. You can use the same piece for more than one race night. I figure when this roll is empty in 2 more years, it will work out to about < 3 cents a race. One roll of tape will last way longer than velcro straps and it just feels more secure using a nice fresh piece of tape than a worn out piece of velcro.
Timbulb is offline
Old 03-22-2012, 06:18 PM
  #6306
LasagnaCat's Avatar
Trader Rating: 161 (100%+)
The TOP strap will work, but can very easily add tweak to your ride. The Puretech Xtreme strap is a much better fit, holds the battery snug while being a bit free at the same time. The TOP strap tends to bind and is easy to pull too tight. The Puretech strap is also thinner and more flexible. The 5 inch strap fits perfectly in a TC6.
http://www.puretechproducts.com/ptprod_straps.htm
(Tape is just... icky.)
LasagnaCat is offline
Old 03-22-2012, 07:07 PM
  #6307
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
good look! I'm buying one tonight!
BlackStarRacing is offline
Old 03-22-2012, 07:55 PM
  #6308
Default TC6 CVJ
New from HKS hobby
TC6 CVJ
HKS Hobby is offline
Old 03-22-2012, 07:56 PM
  #6309
Questions?? Help
Need help setting up my tc6.1. Im running tekin rs pro with 2.5t. The car drives straight, but when I punch the throttle the car feels very loose and hooks sharply to the left. I set the car to factory spec with the increase of 2 deg toe in (kind of help). What am I doing wrong.., could it be chassis tweak?
MySlowZ is offline
Old 03-22-2012, 08:18 PM
  #6310
The Evicerator
Originally Posted by HKS Hobby
New from HKS hobby
TC6 CVJ
Interesting! For 5x10 bearings...?
Steve Weiss is offline
Old 03-22-2012, 08:52 PM
  #6311
Yes orginal bearing
Old 03-22-2012, 09:08 PM
  #6312
Check your droop to make sure it's even. Also, try 3* of toe, or maybe even more.
-Mike
grippgoat is offline
Old 03-22-2012, 11:42 PM
  #6313
New from HKS hobby
TC6 CVJ
Can't find them in your store...
kerb is offline
Old 03-23-2012, 08:40 AM
  #6314
Rick Hohwart's Avatar
Default New Setups Posted
I have just posted the following:
Keven Hebert - 2012 ROAR Carpet Nationals
Olly Jefferies - Cotswold UK Testing
Rick Hohwart is offline
Old 03-23-2012, 08:52 AM
  #6315
if my understand correct,
TC6.1 is 5x10
TC5/6 is 6x10
mos-leung is offline
