Tamiya TB-Evolution IV
#2161
Originally posted by F. Alonso
I want to get a spool for the Evo IV. I have seen the speedtech spool and am wanting to get that, but not happy about the photo id ordering for international orders. Is there any other spool made up for the Evo IV??
If you're interested in a spool from us, please send me an email
Steve Wang
#2162
Originally posted by SpeedTech
F. Alonso,
Steve Wang
F. Alonso,
Steve Wang
Both worked great and Steve's was much cheaper to purchase
vic
#2163
Tech Legend
Trader Rating: 51 (100%+)
I used one of Steve's spools for my Cuda and it worked great. I will get one eventually for my EVO but when I bought my car it already had they tightened spool/diff so I didn't get one yet.
#2164
I use the speedtech spool on my car, and it works really awesome, i race a complete weekend race (8 minutes heats) and i didnt notice any minimal trouble and the car have a great performance
#2165
MAIL!
F. Alonso,
Steve Wang
F. Alonso,
Steve Wang
Guess what!?!?
You've got Mail!
BTW - Thanks for everyone's input on it. I would like to get the Speedtech Spool. Very Strong looking and at a competitive price. What more could I ask ....... blue anodized
#2166
Notes on the spool. In general you will get more breakage running a spool if you hit stuff. In the Evo4 the drive cups break easiest and I now have aluminum ones and they are holding up well. It transfers so much force to the driveshaft, I even bent my Jurgen lightweight shaft. I run the Speedtech spool and it is a single piece of machined steel and looks like it will last forever. I think I would rather have the steel spool than the flex generated from the long slots in the stock plastic diff halves.
The Evo4 hubs from Tamiya are 1 degree in plastic or aluminum. I am using the ones from Square and they are indeed 1.5 degrees.
loosenut: Make sure you use Loctite 242 on the screws for the crown gears that go on the front and rear shafts. Otherwise, they will become loose and cause problems eventually. Your parts list looks pretty good and you will want to add 950 bearings to the list because they do wear out quickly.
#2167
Thx fraz for the tip. Will I need titanium turn buckles? I thought the evo kid don't come with them? Who should I get it from or shall I buy the TC3 ones?
G
G
#2168
You don't need the Ti turnbuckles. I have them but it was mostly to shave weight.
#2169
I don't have Ti turnbuckles on my Evo IV, but I do have them on my 415.
I bought them as I felt I was damaging the aluminium ones as I was adjusting them - I am heavy handed though!
#2170
I have been looking for Ti 28mm turnbuckles for the camber on my Evo IV but doesn't look like Tamiya make them in Ti at that size. I have just bought the 32mm ones and I'm sure that they will fit fine anyway. Like Fraz, only doing it to shave weight as well as having unbendable turnbuckles. Nothing worse then bent shafts, :P :P :P
#2171
The 32mm is probably best in place of the 28mm (they'll go into the ball cups a bit more, which gives it more strength as well) Also, I just sent a reply to your email. I apologize for the delay, I usually don't see the emails from the weekend until Monday (today)
Steve Wang
#2172
free drivetrain
can anybody post some tips on how to make the drivetrain more free? I've set up my car straight from the manual, and it seems to be pretty free. but after seeing a friends pro4, i was absolutely stunned!! i can only get about 8 seconds of free spin from my car. I'll try to attach a small video. i took out the sound, so you'll just have to look at the far wheel to see when it stops!
thanks for the input in advace!!
vic
vic
#2173
the drive train in the evo 4 is pretty free. i compared it to my old evo 3 and there was a big difference. however, the pro 4 is a really great car and im not surprised it has free drive train. wow, if anybody can give any suggestions as how to achieve a really free drive train!
#2174
Tech Legend
My drive is pretty free overall but I got the car used and not sure if all the bearing where sprayed out. I know I did most of them but I did put in one new 950 bearing and it is a sealed one and I know it is tighter than the others. It is still smooth and no binding. It really don't matter if your trans spins for 10 seconds or 30 seconds the track performance will be the same.
#2175
-Dave
